burping radiator
Old Nov 26, 2014 | 08:30 PM
child_of_fire's Avatar
child_of_fire
Default burping radiator
you guys know if there is an easy way to bleed air out of the cooling system? from experience it sounds like i have air in the line. -2009 c6 ls mn6 w/z51
Old Nov 27, 2014 | 05:23 AM
DubsAndSubs's Avatar
DubsAndSubs
When I did mine, I just jacked up the driver side of the car a little bit and ran the car till it warmed up, then let it cool off. I repeated that 3 times, kept the coolant topped off and no problems since.
Old Nov 28, 2014 | 11:01 AM
Bill Dearborn's Avatar
Bill Dearborn
I didn't even do that. Just let the car sit level, opened the reservoir and let the engine warm up. Then I revved the engine to about 3K several times and held it for about 30 seconds each time then topped off the system if required.
Bill
Old Nov 28, 2014 | 11:52 AM
Mike's LS3's Avatar
Mike's LS3
Bill
Continue to do this until air bubbles stop coming to the surface of the reservoir. This procedure is in the service manual.
Old Nov 28, 2014 | 12:53 PM
JDP Tech's Avatar
0JDP Tech
Former Vendor
You can do it a few more times if you wanted to as well; put the cap back on, drive it and get it nice and hot, then let it cool down all the way and repeat.
The more times, the merrier, air in a cooling system is not a good thing.
If you do many repairs on your car (or any car for that matter) it may be worth buying a coolant vacuum filler for $100-200, similar to this one:
We use one like it, it works great and only takes a few minutes to fill the system with no air bubbles.
Feel free to call, email, or PM us anytime!
Thanks!
- Jeremy
Click HERE to send me a PM | Sales@jdpmotorsports.com | www.jdpmotorsports.com | JDP Facebook | 888.308.6007
Old Nov 28, 2014 | 06:53 PM
dennis50nj's Avatar
dennis50nj
Thanks!
- Jeremy
I used that on my truck and it works great, saves the anti freeze and filters it back in, and filled right to the fill line no warming the motor no cooling no bleeding the little line and no bubbles
Old Nov 29, 2014 | 04:57 AM
Whis9's Avatar
Whis9
Thanks!
- Jeremy
Got it and love it
Been using it for years
Old Dec 4, 2014 | 04:30 PM
hrt vlv's Avatar
hrt vlv
As critical as cooling is. The best idea is the vacuum tool, no hassle, one time done, used on I assume i a cold engine, only need one person to perform operation
Bill
Old Dec 5, 2014 | 10:12 AM
MUKAK's Avatar
MUKAK
i wonder if Autozone rents the vacuum pump
gonna call to find out
Old Dec 5, 2014 | 11:44 AM
hrt vlv's Avatar
hrt vlv
I worked at an Autozone for awhile ,no we did not have one to rent or borrow. If you have a mightyvac you may be able to use that. It only has a 4oz container though.The mightyvac can also be used for testing, spark advancer, any vacuum operated device, bleed brakes,etc. The JDP tool was not that costly of a tool.
Old Dec 6, 2014 | 05:57 PM
truckplay's Avatar
truckplay
I cut the bottom out of a 2 liter bottle of coke, I placed the neck into the coolant bottle and filled the bottle 1/2 way. start the engine and let it come up to temp, when the t-stat opens the coolant will be sucked down as the air is released.
To burping radiator
