Window switch issues...anyone run across this?
Old Dec 9, 2014 | 05:10 PM
BigC6Mike's Avatar
BigC6Mike
Default Window switch issues...anyone run across this?
I'm having issues with my 05 C6 window switch on driver side. All functions work except for raising the passenger side window. I can drop the passenger window but I can't raise it. I have to end up extending myself to the passenger side and raising it from there. I predicted water must have somehow leaked into the switch messing something up. I took the driver side switch apart, and besides a little bit of dirt it didn't look too bad. I took it all the way down to the board and cleaned the board with alcohol and from what i can tell all seemed well. I didn't use a electrical tester yet, but i figured I'd ask here maybe this is a common problem or something. I have searched around in this forum, I haven't came across this. If I do just need to buy another switch, can someone guide me to the right place? Dealership wants like $125ish. Thanks
Old Dec 9, 2014 | 05:53 PM
cclive's Avatar
cclive
For $125 ish, I would be getting that multimeter out and testing the switch. This is not a common problem. You might also check the circuit by using a jumper and bypassing the switch.
Old Dec 9, 2014 | 06:05 PM
BigC6Mike's Avatar
BigC6Mike
Multimeter...thats the word. Idk why I said tester. Ya i haven't done that yet. I heard with window switches that have auto-down that it goes through a module, and bypassing with a jumper doesnt work or might mess things up
Old Dec 9, 2014 | 06:24 PM
cclive's Avatar
cclive
That's a good point, if the module is inside the switch. It also may be that the switch is just a simple switch. I haven't had one open but it should be fairly simple to analyze once it's disassembled. Good luck and be sure to report back. If the switch were $20, I might just toss it, but for more than $100, I would be willing to spend some time on it.
To Window switch issues...anyone run across this?
