DRL - LED Lamp Issue
Old Dec 14, 2014 | 07:14 PM
boraxman's Avatar
boraxman
Default DRL - LED Lamp Issue
Thought I would install some white LED DRL's....Well I noticed the pass side was a bit brighter and upon driving around it burnt out and melted the base (see pic). Tried a couple more LED lamps with the same results, so I think I can rule out the lamps, however they were cheapies....
Funny the stock bulbs work fine...Anyone else experience this?
Old Dec 14, 2014 | 09:07 PM
tennblkc6's Avatar
tennblkc6
get a set of these switchback leds...love mine.
https://www.corvetteforum.com/forums...rls-on-c6.html
Old Dec 14, 2014 | 09:39 PM
boraxman's Avatar
boraxman
Want LED but before I spend more I think I need to find out if theres a electrical issue going on.
Old Dec 14, 2014 | 10:44 PM
RicK T's Avatar
RicK T
What year is your car?
'05 - '07 had a wiring harness issue.
Old Dec 14, 2014 | 10:53 PM
boraxman's Avatar
boraxman
It's an ''08
Old Dec 15, 2014 | 08:44 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Cheap LED bulbs. I tried a set and could not get them to work properly either. Get a better quality bulb and you should be fine. Hope you didn't burn your socket but sound like if factory bulbs work still you are ok.
To DRL - LED Lamp Issue
