I know I used it on my old 2006. My friend is picking up a 2009 and he is going to swap wheels. Does this tool also work on the 2009 models? If so, is 2009 the last TPMS sensor year that it will work on?
looks like it works for both the 2005-2009, and the 2010-2012 vets tmps's.
2009 was the last year for the first type of TPMS, and in 2010, gm changed the TPMS to the newer style/The programing on the RCDLR to pick up the different signal of the new style tpms's.
To add, if you have a program tool that is only current to 2009, then your still good on using it for the 2010-2012 models. The reason for this, the 2009 HHR used the same tpms as the 2010 to 2012 vets (read if your tool is not automatic in setting selection, then you just need to select 2008 HRR to reset the newer vets).
