I've put an LS7 into two of my personal cars and one into a friend's car, all of which originally came with an LS2.
What is it that you need to know?
Just wanted to know more about the actual physical swap. I read in the GM performance parts catalog that the LSX 454 will accept all the factory accessories, and that it's the std. deck block, so it should look like it's the stock engine. Basically, whose done one of these swaps that could share some words of wisdom. Another thing, can a factory C6 manual transaxle handle the power of this engine?
The LSX 454 uses an LS7 intake. It uses an 8 bolt flywheel. Get one for a CTSV. I used a Vintage Air front Runner accessory drive and I had to mill a 1 1/2 inch recess in the back side driver side p/s alt. bracket to clear a freeze plug that protrudes further than on the aluminum block. Other than those hiccups everything bolted together just like any other LS. It did lower the front of my car about 3/4 of an inch because of the added weight of the iron block.
What car did you install it in? You couldn't use the factory accessory drive set-up from your car? Thanks for your input!
I used it in a 57 chevy 150 sedan. I had the stock accessory drive on the LS2 but I switched to Vintage Air Accessory drive when I installed the Lsx 454. My thought would be that it will fit. I can't imagine that chevy didn't take that into account when they designed the iron block.
I do have a LSX454 crate motor in my C6. It has the 6L80E trans. It has been tuned. It has an additional trans cooler as well as an additional oil cooler. It produces 533 hp to the ground with 504 ft pounds of torque. It is very drivable. Yes it is100 pounds heavier than the original LS2. It's a blast to drive!
Lance Kelly has placed the crate motor LSX 454 into a c5. You can get some insight from him. I have place my LSX 454 crate motor into my c5z, fits in with minimum cutting and folding. I have a c6 rear carriage to support a zr1 drive train. Andy at AA corvettes put in the supercharger.
