2 or 3 Bar MAP question
Old Dec 26, 2014 | 02:45 PM
GeneSch's Avatar
GeneSch
Default 2 or 3 Bar MAP question
Adding a blower to my 06 C6Z.
If I change the stock MAP over to a 2 bar or larger, will I have to tune in speed density or will I still be able to read off the MAS?
If changing to SD is a must when going to a 2Bar sensor, what's better? Only going to run 5-7lbs of boost. I want what ever is going to be best for daily and street use. I'm not building a race car.
Old Dec 26, 2014 | 04:15 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You can still use your MAF... no problem. What is better is another debate. Some run MAF only, some SD, and some blended. I guess it is whatever our tuner is most comfortable with. Personally, I run MAF only and like it that way.
Old Dec 26, 2014 | 06:51 PM
C6z06man's Avatar
C6z06man
I personally like tuning speed density. And on higher HP boosted cars it makes it run much smoother.
Old Dec 27, 2014 | 02:48 PM
GTPSS's Avatar
GTPSS
This!
My 1000awhp TBSS would barely run on MAF, switch to SD and it extremely smooth.
Old Dec 27, 2014 | 10:30 PM
C6z06man's Avatar
C6z06man
Originally Posted by GTPSS
This!
Yeah ive driven high HP cars that you can't even tell is modified. Standalone makes it even smoother.
To 2 or 3 Bar MAP question
