brake swap question
Old Dec 28, 2014 | 02:17 PM
360Rocket's Avatar
360Rocket
St. Jude Donor '12-'13-'14
Default brake swap question
What would I need if anything to put front Z06 calipers and rotors on my 05 Z51 C6? The rims being 18" on both models shouldn't require new wheels I hope?
yeah i tried the search function, its hard to know what key words to use in search to bring up what you are specifically looking for.
Old Dec 28, 2014 | 02:23 PM
timd38's Avatar
timd38
Stock wheels won't clear the calipers.
Old Dec 28, 2014 | 08:00 PM
Dano523's Avatar
Dano523
8mm spacers and ET lug nuts to give the needed clearance between the caliper and the rims.
https://www.corvetteforum.com/forums...l-spacers.html
http://www.billetspecialties.com/e-t...g-nuts/999978/
http://www.rpidesigns.com/shop/item.aspx?itemid=2968
If you are going to track the car, then forget the Et lugs, and get longer studs instead.
Old Dec 28, 2014 | 08:05 PM
timd38's Avatar
timd38
You have to remove the hubs to install the longer studs.
Old Dec 29, 2014 | 04:45 PM
tgcounts's Avatar
tgcounts
Default Brake Options
What is your intention for the car? If just wanting bigger brakes, you can find Z06 brakes on ebay pretty cheap. They can dress the car up nicely but you're really not going to gain a ton of additional braking. Some, but not a lot. IF you go Z06 brakes, you can use the brakelets or there are full size pads you can use now that are a lot less frustrating.
IF you plan on tracking, then I recommend moving up to Wilwood, AR, Brembo, etc. Lots of options depending on your wallet. I use Wilwoods and am quite happy with them. Nice bang for the buck.
Whatever you choose, you'll need additional clearance (bigger wheels or spacers) to clear the non-floating nature of big brakes. I just posted pictures of Ace Alloy R666s that I got on sale (year-end) that have a ton of room.
If you're just going to drive the car, spacers are the easy route. I have spacers on my split-Y wheels for puttering around town. I have wheels that fit correctly for the track.
I did replace the hubs with SKF's and 2.5" ARP studs. Given that I track the car, it made sense. Again, if you're NOT tracking, then stock hubs will be fine, just change out the studs. Easy and not very expensive.
Good luck!
Tom
Old Dec 29, 2014 | 05:04 PM
timd38's Avatar
timd38
I did what you did and installed SKF hubs with ARP studs, but I did try to change wheels studs without taking the hubs off and if your steering knuckle is the same as mine, longer studs won't clear the angle needed to get them on in the front. Getting those three torx bolts out that hold the hub on are a real challenge. I never tried the rears studs, I just replaced the hubs.
Old Dec 30, 2014 | 05:54 AM
Dano523's Avatar
Dano523
Tgcounts, Ditto on that,
The brakes upgades are only going to work as well as the grip of the tires.
Once the tires stop gripping and the ABS kicks it, it pretty much over for any upgrade mods that you did to caliper and rotors for better braking.
Old Jan 3, 2015 | 08:17 AM
360Rocket's Avatar
360Rocket
No tracking just street use. If there isn't a gain to be made in braking then it seems like a lot of unneeded expense and labor that could be better utilized elsewhere. thanks gang.
Old Jan 3, 2015 | 10:15 AM
timd38's Avatar
timd38
Good move! Sometime the juice just isn't worth the squeeze!
Old Jan 4, 2015 | 08:56 PM
byte_me's Avatar
byte_me
https://www.corvetteforum.com/forums...-complete.html
Here is my thread when I did this exact conversion on my 05 Z51. Awesome setup and many, many happy miles with some seriously large brakes!
PM me if you need any help/info!
Old Jan 4, 2015 | 10:35 PM
360Rocket's Avatar
360Rocket
wow nice write up. now I see these lug nuts and spacers and longer studs, wont all this push the wheels outside the fender wells? I.m soon swapping over to an aftermarket wheel as well. Im assuming if the stockers will clear the Z06 calipers, the aftermarkets should as well.
Old Jan 5, 2015 | 07:02 AM
byte_me's Avatar
byte_me
The 1/4" or 6mm spacers I used do not push the wheels out past the wheel wells- in fact, you hardly notice them out at all... I still have a bite on the hub when I put the wheels back on which is nice. I used the stock wheels studs (did not replace them) and went with extended thread lug nuts (ET). You can buy the spacers and lug nuts from the guys I listed in my thread on the conversion. The spacers are beautiful, the extended lug nuts will give you back the necessary thread turns you lost by pushing the wheels out 6mm.
If you are going after market wheel set, be sure that they clear the big calipers- I chose to use the "Gumby" OEM wheel from the 08 and up Vette's. At that time, they were the only stock GM wheel that would clear the brakes using a spacer in 18/19"... The wheels are also forged so you get super strong wheels and in my opinion, the best looking base C6 wheels GM made... The big open spokes really show off this Z06 calipers!!
To brake swap question
