cam swap question
Old Dec 29, 2014 | 12:18 PM
slow goat's Avatar
slow goat
Default cam swap question
I was planning on swapping heads and cam together but, I am missing a few miscellaneous parts for the head swap. I've recently found out that the shop I go to (with a lift) that's let's you do all the work yourself, will be closing soon. I figured I'd go ahead and do the cam swap and crank pin since I can utilize the lift there and do the heads later since that requires no lift. Question is, can I use the ecs small blower cam with stock springs for now since my new heads have the new springs on them. The lift on that cam is .580.
Sent from my HTC One using IB AutoGroup
Old Dec 29, 2014 | 12:29 PM
Jared@RPP's Avatar
0Jared@RPP
Former Vendor
I would not trust the stock springs to that much lift honestly, I can get you set up with a nice set of dual springs with Ti retainers, I would just recommend doing it all at once so theres no chance at dropping a valve from worn guides/extra spring pressure
Old Dec 29, 2014 | 03:02 PM
Speedforhire's Avatar
Speedforhire
The stock springs are rated to 550 lift under high revving conditions. They are good to 580 lift for normal cruising. So to answer your question - yes, you can drive it easily on the stock springs until you get the heads swapped. Don't rev the motor past 3K rpm.
Old Dec 29, 2014 | 05:23 PM
slow goat's Avatar
slow goat
Sounds risky. I think I'll have to try and do the heads together.
To cam swap question
