Squeaky Brakes - 2011 GS
Old Jan 10, 2015 | 11:28 AM
blueman166's Avatar
blueman166
Default Squeaky Brakes - 2011 GS
I just got back from taking my 2011 GS out for a drive after it's been setting for about a month and now it has squeaking brakes when I slow down to stop. The car has 17,000 miles and the brakes were checked by my local Chevrolet dealer at it's last service, so I don't think I need new pads. Any ideas how to stop the squeaking? Any help would be appreciated!!!
Old Jan 10, 2015 | 12:15 PM
dmoneychris's Avatar
dmoneychris
Same thing here. (2013 GS) Squeaky brakes & excess brake dust. (I will be changing brake pads soon). In the mean time when they start squeaking, I speed up before a stop sign/light & then I hit the brakes really hard. One good, hard stop cures the squeaking brakes for the rest of that day. The brake dust has been an on going problem though that seems to be incurable w/the OEM pads. I will be upgrading pads very soon...
Old Jan 10, 2015 | 06:48 PM
petsur's Avatar
petsur
Upgrading or do you mean downgrading? Stock brakes stop the car very well.
Old Jan 10, 2015 | 08:17 PM
dmoneychris
Side-grading (http://brakeperformance.com/brake-pads/brake-pads.php) I think I'm going to go w/the 'Premium Semi-Metallic' pad material.
Old Jan 10, 2015 | 08:59 PM
byte_me's Avatar
byte_me
Autozone. You and your wallet will thank me later!
Old Jan 11, 2015 | 05:15 AM
Mainn's Avatar
Mainn
A long drive with a lot of braking should make it go away.
Old Jan 11, 2015 | 07:09 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
My 13 GS gets worse with a lot of braking. When we ran the Dragon it got pretty bad by the end. To reduce the squeal I would stab the brakes, then let off and stab again. With 12,700 on the car now it looks like new pads this spring or summer.
Old Jan 11, 2015 | 12:32 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
For a high quality brake pad that performs and is quiet and low dust look at the Carbotech 1521 pad.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Jan 12, 2015 | 06:23 PM
slapshot12's Avatar
slapshot12
Veteran: Coast Guard
Are those padlets or 1 pc pads? Ceramic I assume?
Mine have a light squeal which i can deal with, it's the brake dust that drives me insane. Reminds me of the BMW's before they went to ceramic pads.
Old Jan 12, 2015 | 07:23 PM
byte_me's Avatar
byte_me
Padlets
And honestly- unless you are tracking your car, I cant see spending $500 for pads when you are just weekend cruzing or daily driving. These things are dead quiet, 90% less dust then OEM, and offer excellent braking. All for under $100 (front and rear) if you find a coupon code!
Old Jan 12, 2015 | 08:07 PM
MBB's Avatar
MBB
My Z brakes on my base squealed. My brakes on my 2011 base (18k miles) squeals like a stuck pig when I slow down. More precisely it squeals just before stopping. I've come to accept that this is just a Z/GS brake characteristic.
Old Jan 13, 2015 | 12:40 AM
quickcat's Avatar
quickcat
Padlets
I concur with this..... Good advice for ZO6 and Grand Sport owners out there.
The stock pads are real good performers but will scream like race car brakes. THIS IS NORMAL. Please don't bother your shop by having them look for the noise.
Matt
Old Jan 13, 2015 | 09:08 AM
Carbotech Adam
Supporting Vendor
These are made in Padlets and 1 piece design.
Old Jan 13, 2015 | 11:22 AM
MBB's Avatar
MBB
1 pc > Padlets... I was so happy after I made the switch.
Old Jan 13, 2015 | 11:34 AM
Bill Dearborn's Avatar
Bill Dearborn
Several people have noted how the brakes squeak more just as they reduce pressure before coming to a stop. The way to reduce this is to increase the force on the brake pedal. Stop the car in less distance so you have to keep the brake applied hard until the wheels almost stop turning and then relax pressure on the pedal to keep the nose of the car from bouncing when it stops.
It takes some getting used to but you do not need to drag the brakes to stop at stop signs or traffic lights. Just go deeper toward the traffic device and use your brakes harder. No extra wear on the brakes or tires and the squeaking will go away. Start by going 50 ft deeper and if the car comes to a nice stop without hassle, cut another 50 ft and repeat until you are applying the pedal hard all the way to the stop with the slight release just before the wheels stop turning.
You are driving a sports car with brakes made for much harder use than the typical grocery getter. Drive it like it should be driven or drive like your great grandmother taught you how to drive.
Bill
Old Jan 13, 2015 | 06:42 PM
Spanish Fly's Avatar
Spanish Fly
I am dealing with this very issue at the moment. Grrrr
Old Jan 13, 2015 | 07:43 PM
HBsurfer's Avatar
HBsurfer
Bill
I was told this early on and my brakes do not squeek anymore.
Old Jan 14, 2015 | 01:46 PM
MBB's Avatar
MBB
Bill
This is exactly when mine does it. Just before the stop it'll squeal like a btch. Thanks for the tip Bill!
To Squeaky Brakes - 2011 GS
