I just purchased a 2009 Vert, automatic trans.
When I was putting the rear license plate on I noticed that the two vacuum hoses there are supposed to be connected to the mufflers were cut off and just hanging there --- and the cut lines were not pluggged up or capped off that I could see. I guess this was done so that the previous owner got a louder exhaust sound all the time. But doesn't the vacuum come from the intake manifold and wouldn't leaving these lines unconnected and unplugged cause engine running problems. Engine seems to run fine. I don't understand how this system works and I want to restore the muffler operation back to stock so the exhaust sound is quieter unless I'm pushing it. How does this system work and if the vacuum does come from the intake manifold why does it not seem to effect the running of the engine (unless the vacuum is plugged somewhere else ).
check to see if the fuse for the npp is still there then have someone start the car while you put a finger over the hose end to see if vacuum is present.
see if the mufflers have the valves to open the baffles. if they don't, you may have an aftermarket system. have someone start the engine while you press your finger up to the hoses, if they are connected, you should feel vacuum. the hoses are attached to the rear of the intake.
Check the back of the intake manifold to see if the vacuum line was pulled and a cap plug put back on to cap the port.
where is this vacuum port on the intake manifold?
right side? Left side?
Do I have to remove the fuel rail covers to see/find the vacuum port?
Anybody have a picture so I know what to look for?
Are the mufflers the only things that run on vacuum on this car?
IF its orig equipped npp (did you check sticker in glove box?) the vac line is center back of manifold.
if its NOT orig equipment it MAY be connected there or in front of manifold.
It turns out I have a stock npp system. Today I just connected those cut and hanging vacuum lines to the mufflers and presto --- everything worked. What I don't understand is why the engine was running OK with those two vacuum lines hanging, unplugged and unconnected --- sucking in gobs of air into the intake manifold. Seems to me the computer should have been throwing codes left and right. I guess I really don't understand how this whole system works. But for sure, the car now runs quiet --- too quiet -- and I will need to do something about that.
Thanks for all your suggestions and analysis. If anybody can explain why the engine ran find even though those two vacuum lines were open and unconnected --- then please explain.
Maybe the length and diameter of the vacuum lines to the mufflers was restrictive enough that the effect on the engine vacuum was barely noticeable. That is a very long run of a very small diameter tubing from a very small opening in the back of the intake manifold.
Notice the size, length and diameter of the power brake vacuum line right beside the NPP tap. Huge hose for a short distance run. If that one was open you would notice the vacuum leak.
