change vararam filter
It was never easy for me but then I am not gifted in this area.
Not sure which generation you have but double check the seal when closing and look for debris that got past the seal. If so you have a closure problem, which was common with the earlier units, I understand that Vararam had redesigned the unit for better fitting, so I hear but I have no experience with the newer design.
Paper filter replacements
You'll need to slightly trim/sand off about 1/8" of the rubber seal on each end. So if you drive in an area with a fair amount of dust the paper filters trap a whole lot more dirt, but do slightly restrict the airflow.
Amsoil - EAA240
Purolater - A25596
Fram - CA10085
NAPA - 9186
WIX - 49186
STP - SA10085
Carquest - 83186
These are replacements for VW 2.4 L from about 2006-2012.
According to the numbers, it looks like Carquest, NAPA, and WIX are identical and Fram & STP are also twins, so you might as well shop by price.
The bottom line is that the best filter is at it's best on the day you take it out and the best performance is with no filter at all. Everything else is a compromise. Pick your poison.
Very low mileage, The car only has 13000 miles. I will share my experience when I get into it.
I tried loosening two of the metal bands but the thing was still stuck on solid
I tried accessing it from the front where the clips are, but that didn't work either
Ive put on 14 000 kms since buying the car and I need to clean this thing , any help would be appreciated thanks
I have a 2011 grand sport
Thanks in advance
I did it myself today and in all honesty , for anyone else in my position, its a lot easier then it seems
You loosen the first two clamps before the MAF, and the two flip style clasps down by the filter housing itself , and wiggle the entire piece out, it came out with relative ease and went bac in even easier.
Now onto the good stuff, in my honest opinion this vararam works AMAZING, my filter was absolutely filthy, worst ive seen , but when u look on the other side of the filter, it was spotless, the inside of the intake was also spotless, nothing got through and I couldn't of asked for a better outcome.
I hope my vette forgives me for taking so long to clean the filter, but its all done now and for anyone who is struggling with this don't worry, its easy.
Disgusting
Cleaned this up thoroughly before re assembly
Caked in dirt
This is the backside of the filter, looks clean enough to eat off , im very impressed with vararam, not a speck of dirt got through , well done
