Tough to do since the manual doesn't have a temp sensor that I am aware of.
I don't think the manual trans has a sensor either...and no program can get a temp reading of something unless there is a sensor hooked up to the system. The auto trans has one.
I set it to monitor oil temp and transmission temp on the same screen, and this morning, the oil temp got to 159 degrees, and the transmission temp got to 121 degrees. Both started out at 64 degrees when I fired up the car to leave, it was parked outside.
This was about a 20 mile drive in the dark, mostly interstate driving, with the outside temp on the HVAC unit was 63 degrees.
