C6 Mode Door Actuator Replacement
Old May 28, 2024 | 08:28 PM
tennblkc6's Avatar
tennblkc6
changing the actuator didn't work for me. so I left it connected but not installed. I started the car..turned the white round **** until the air was blowing out of the vents and buttoned it up. I will do the same when winter comes.
Old Jul 15, 2024 | 12:09 PM
Madmax13C6's Avatar
Madmax13C6
6th Gear
Default Mode door.
Originally Posted by cclive
Nice instructions. I had always been under the impression that the dash had to be removed to do this. As I was reading, I was thinking "who cares about the price of the actuator? The labor will be $1,000". Nice job...thread saved.
Thank you for the step by step.
My car is fixed.
Old Nov 16, 2025 | 08:08 AM
Leigh Shepherd's Avatar
Leigh Shepherd
7th Gear
Hi, Great description, thanks. Is there a blend door actuator on both sides of the car - dual air? I get hot one side, cold the other!
Old Dec 6, 2025 | 10:57 PM
C6VetteLover's Avatar
C6VetteLover
Fantastic write up, all of my HVAC mode work as designed but I do get the occasional clicking from the passengers side so I guess I will follow these instructions and see if I can see anything.
Old Dec 14, 2025 | 03:51 AM
Fireblade's Avatar
Fireblade
4 actuators total, 2 of them are temperature actuators, right and left as you said. The left (driver) one is easy to replace, the right (passenger) one requires removing the dash.
