Need help!! P0606 & P1516 codes
Old Jan 29, 2015 | 09:30 PM
Proracing's Avatar
Proracing
Default Need help!! P0606 & P1516 codes
Car is an 07 C6 Texas speed 421 stoker with a Maggie TVS 2300 that has been recently converted from auto to a full Z06 6 speed drive train. Car is throwing a few codes. First it threw 2, P0606 and P1516. We changed out the throttle body and the P1516 code went away. Then we put in a new PCM and the P0606 code went away until I turned traction control off. Weird I know. So with traction control on no P0606 code but as soon as you turn it off it throws the P0606 code. Have no clue what's going on. So I drove it home with traction control on and no issues till I was driving for about 5 minutes then the check engine light came on. The P1516 code again but no other codes. Cleared it and it came back. Did this about 7 times. Car drives great, no limp mode, no reduced engine power just the check engine light and the P1516 code, unless I turn traction off then I get the P0606 code and reduced engine power. I'm at a loss with this. Is it a wiring issue, something not wired correctly or not at all? This all usually happens with light throttle not wide open. At wide open throttle it doesn't throw any codes. Has someone done an auto to manual swap before and had these issues. Any help would be greatly appreciated!!!
Old Jan 29, 2015 | 09:38 PM
timd38's Avatar
timd38
Here is a code list. I am not smart enough to help you.
http://www.dmv.de.gov/services/Vehic...s/dtc_list.pdf
Old Jan 29, 2015 | 09:43 PM
Proracing's Avatar
Proracing
Thanks for the help!!!, I've already found what the codes are, just need a way to figure out how to proceed from what we've already done. Thank you again!
Old Jan 30, 2015 | 11:54 AM
Proracing's Avatar
Proracing
Ttt
Old Jan 30, 2015 | 12:10 PM
Speedforhire's Avatar
Speedforhire
PO606 = ECM/PCM Processor..........factory set to SES Enable and 0-MIL on First Error, which means it will throw a CEL on it's first reported error.
P1516 = Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance.........factory set to SES Enable and 0-MIL on First Error, which means it will throw a CEL on it's first reported error.
My advice: Check VSS settings and make sure the trans/system settings are updated to reflect the swap.
Old Jan 30, 2015 | 12:25 PM
Proracing's Avatar
Proracing
Thank you!! I will have the shop check into that asap.
Old Jan 30, 2015 | 12:41 PM
Speedforhire
It's been my experience in life that it's always the simplest things that cause the most problems.
I hope it helps and keep us in the loop please.
Old Jan 30, 2015 | 12:43 PM
Proracing's Avatar
Proracing
That sir is very true, always the simplest things.
Old Jan 30, 2015 | 09:47 PM
Speedforhire
Is this your car?
It looks like your avatar.
Old Jan 30, 2015 | 10:47 PM
Proracing's Avatar
Proracing
No, I wish lol. I still haven't been able to paint the front end yet. Been waiting till I finish with everything else before I spend the money on paint so nothing gets scratched.
Old Jan 31, 2015 | 04:02 PM
Proracing's Avatar
Proracing
Bump
Old Jan 31, 2015 | 10:09 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Are you still using the ls2 throttle body? I tried using an ls7 tb on an ls1 and the tac module did not like it. I installed an ls2, no problem.
Old Jan 31, 2015 | 11:25 PM
Proracing's Avatar
Proracing
It's the same throttle body I've had in the car the entire time. From the stock motor to the stroker motor, auto and now manual. It is an LS2 throttle body. Don't see how going from auto to manual would all of the sudden change what throttle body I would need.
Old Feb 1, 2015 | 10:43 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
It wouldn't ! I was asking if it was changed because of what happened to me. Just trying to help.
Old Feb 1, 2015 | 10:46 PM
Proracing's Avatar
Proracing
Sorry, didn't mean to come off the wrong way. Just been super frustrated with this whole thing. I appreciate any and all help!!
To Need help!! P0606 & P1516 codes
