aftermarket fuel pumo
Old Feb 2, 2015 | 07:24 AM
curtisb23's Avatar
curtisb23
Default aftermarket fuel pumo
Witch aftermarket fuel pump is recommended? I don't want oem or any other type of oem pump aftermarket is what I'm after .looking for a drop in fuel pump
Old Feb 2, 2015 | 08:11 AM
Eckler's's Avatar
Eckler's
St. Jude Donor '04
I checked my inventory and it looks like we only carry one. I will link it below.
FUEL PUMP
Old Feb 2, 2015 | 08:24 AM
curtisb23's Avatar
curtisb23
Thanks ,that's a lot over kill for me haha ,looking for a drop in in place of the oem
Old Feb 2, 2015 | 08:26 AM
Eckler's's Avatar
Eckler's
St. Jude Donor '04
LOL!! I can understand. I thought we had more than one. Sorry. Good luck with the search.
Old Feb 2, 2015 | 08:32 AM
curtisb23's Avatar
curtisb23
Thanks tho
Old Feb 2, 2015 | 09:05 AM
timd38's Avatar
timd38
The pump is cheap compared to the labor.
I would just buy a Z06 pump and move on. In fact I believe that most of the replacement pumps are Z06 spec to reduce stocking complexity.
Old Feb 2, 2015 | 09:18 AM
curtisb23's Avatar
curtisb23
The z06 pump isn't going to suport a different fuel when I decide to do so
Old Feb 2, 2015 | 09:25 AM
timd38's Avatar
timd38
Then you need to spend the big bucks!
Old Feb 2, 2015 | 10:29 AM
curtisb23's Avatar
curtisb23
There are drop in replacement aftermarket oem pumps out there just wanting to see who's doing it an witch pump
Old Feb 2, 2015 | 02:59 PM
chpmnsws6's Avatar
chpmnsws6
http://www.lingenfelter.com/mm5/merc...1#.VM_W83tWxi0
Old Feb 2, 2015 | 03:25 PM
curtisb23's Avatar
curtisb23
Just talked to hhp chuck out in Texas said the dw300 so just ordered that
Old Feb 2, 2015 | 03:33 PM
chpmnsws6's Avatar
chpmnsws6
Post up once you get the DW pump in. I had one in my swapped LS1 Miata and it worked GREAT after the Walbro died.
Old Feb 2, 2015 | 03:47 PM
timd38's Avatar
timd38
How do you install it? Cut the old pump off the bracket and attach this one?
Old Feb 2, 2015 | 03:57 PM
chpmnsws6's Avatar
chpmnsws6
Good. Post pictures. I haven't had my hands in this tank yet
Old Feb 2, 2015 | 08:02 PM
curtisb23's Avatar
curtisb23
Will do comes in tomorrow
Old Feb 3, 2015 | 03:35 PM
curtisb23's Avatar
curtisb23
Well the dw300 was a grate fit ,replaced the plastic feed line and used a oem fuel filter the filter that comes with the pump doesn't work inside the bucket but it's all done very easy to do
Old Feb 3, 2015 | 05:21 PM
chpmnsws6's Avatar
chpmnsws6
Pics?
To aftermarket fuel pumo
Old Feb 3, 2015 | 05:33 PM
1Hotrodz's Avatar
1Hotrodz
Which witch?
Old Feb 3, 2015 | 09:54 PM
curtisb23's Avatar
curtisb23
You know I was gna take some pics but it all whent so fast an smoth I forgot lol still need get trans back in an I'll fire it up
Old Feb 20, 2015 | 01:25 PM
chpmnsws6's Avatar
chpmnsws6
So the stock sock fits on the DW300?
Have you fired it up yet?
I'm looking to order here soon. I want to get rid of the BAP and get a real pump in before Spring hits.
