Tr6060 rebuilding thoughts
Old Feb 3, 2015 | 11:24 PM
O7r6's Avatar
O7r6
Cruising
Default Tr6060 rebuilding thoughts
So my tranny finally needs a rebuild and just having some thoughts between a couple options. So I firstly I have a 08 base putting down 549hp with 462lbs and I'm debating either rebuilding it my self which I'm fully capable of sending it to have someone do it for me, power wise I don't plan on putting anymore down for a couple more years and I'm truly thinking of rebuilding it my self I was just wondering what the best parts setup to do with the power I'm putting down I don't do digs I more or less do track days and threw way rolls
Old Feb 4, 2015 | 05:35 AM
dev1360's Avatar
dev1360
Thegearbox.org will have all you need.
Carbon blockers in 1-4, and bronze pads are all you need.
I rebuilt mine, it's really not a hard job if you have access to information and tools. May be best to let a pro do a full rebuild. You will need to set bearing preload and the special pulling tools are nice.
Old Feb 4, 2015 | 01:29 PM
kedar's Avatar
kedar
St. Jude Donor '12
The choice is simple: send it to RPM Transmissions in Indiana and have them rebuild it.
Old Feb 5, 2015 | 12:41 PM
mattdracing's Avatar
mattdracing
If it were me...I would definitely send it to RPM Transmissions. They are the experts on that. I plan to have them do a built trans for me very shortly. My buddy's zr1 has their level 6 build and it is nice
Old Feb 5, 2015 | 02:20 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Here's a how-to if you are interested.
https://www.corvetteforum.com/forums...d-rebuild.html
Justin (Juic3d) and I had a conversation about this. I have watched a guy rebuild my transmission who does it for a living, and he showed me parts that he said were bad vs new. I candidly couldn't tell the difference. I warned Justin that he would not know what was bad vs good without the experience and training as the difference between good and bad is so esoteric. Thus, in my opinion, without the training you might not replace parts that were bad, or conversely, replace good parts unnecessarily.
He ended up doing it himself and even posted up the how to. I think it worked out for him.
To Tr6060 rebuilding thoughts
