Dyno was a success!
Old Feb 5, 2015 | 06:44 PM
g8gt208scvette's Avatar
g8gt208scvette
Default Dyno was a success!
Car made 791hp / 835 tq...belt slipped on first run....tightened down and made some great numbers!! Tuned by Billy Whatley (Machine Works)
Old Feb 5, 2015 | 06:59 PM
timd38's Avatar
timd38
Stock LS3 with Granatelli wires?
Old Feb 5, 2015 | 07:01 PM
Dano523's Avatar
Dano523
Epic!!!!!!
But one question, why did the motor/hp go flat at 5K?
Did you run out of ejector spray amount, pump pressure, or boost increasing pressure.
At your HP climb rate to 5K, it it did not go flat after that, should have been in the 800rwhp range at 6.2K instead.
Myself, it only 650rwhp in on the table, would have rather had the motor turned to produce that at red line instead with a clean climb (6.2K), which gives you a wider Rev range for useable HP for road/road course use instead.
Hence the higher that a motor will rev/ has in useable HP Rev range, the easier it is to drive the car.
Old Feb 5, 2015 | 07:21 PM
g8gt208scvette
Originally Posted by Dano523
Epic!!!!!!
belt slip on the first run as stated in the OP duty cycle was @ 52% WOT
Old Feb 5, 2015 | 07:35 PM
C6z06man's Avatar
C6z06man
Wow. Great numbers!!!
g8gt208scvette
402 stroker blower cam
Old Feb 5, 2015 | 07:37 PM
timd38's Avatar
timd38
Very nice!
Old Feb 5, 2015 | 07:43 PM
g8gt208scvette
Very nice!
Yeah sorry for not posting up my build lol...folks usually like to know what's making the power so here is my entire build..
-LY6 Iron Block
-Callies Compstar 4340 forged 4.0" stroke (stroked to 402)
-Cam Motion Custom Grind Cam - 227 241 .630 .630 115 +4
-Ported LS3 Heads
-Clevite MS 2199 H mains, Clevite CB 663 H rods, DuraBond CH-23 cam bearings
-Callies Compstar 4340 6.125" H beam connecting rods
-Manley 1 piece chromoly push rods
-Wiseco forged pistons
-Manley L92 stainless 1.600" exhaust valves
-Rollmaster double roller timing set w/ torrington bearing and nitrited gears
-Melling 10295 high pressure oil pump ported
-Procharger D1SC w/ DP Big Mouth Kit & 4" pulley
-TiAL q BOV
-IAT relocation kit
-AEM Meth kit
-OBX 1 7/8" headers & Magnaflow axelbacks
-Innovators West 10% OD Balancer
-McLeod RXT Clutch
Old Feb 5, 2015 | 07:48 PM
timd38's Avatar
timd38
Nice combo that makes a ton of power!
Old Feb 5, 2015 | 08:45 PM
xBoostx's Avatar
xBoostx
Default Very nice...
Dyno power lines are perfect and typical of boost cams.
Old Feb 5, 2015 | 08:57 PM
g8gt208scvette
Yeah I talked to Billy and he said it is perfect...he is overly pleased with it. Especially the Torque it made...the motor was built my Late Model Engines and Bryan at LME specced the cam based of the stroker motor and blower so it was all well put together.
Old Feb 5, 2015 | 10:07 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
stock fuel system?
Old Feb 5, 2015 | 10:11 PM
g8gt208scvette
Originally Posted by GS057
stock fuel system?
no a&a fuel system.....100# injectors
Old Feb 5, 2015 | 11:06 PM
HOXXOH's Avatar
HOXXOH
Nice power. Sounds like a strong build too.
What mods are you doing to put that power to the ground?
Old Feb 5, 2015 | 11:09 PM
g8gt208scvette
just M/T street radials and c5z06 axels right now
Old Feb 6, 2015 | 10:19 AM
Mike Farris's Avatar
Mike Farris
Epic!!!!!!
The blue line does peak and hold from 5250-5750 then decline some. This isnt too far from the peaks of a lot of stock ls motored cars. Its more than likely the blower running out of steam. Even the smaller F series blowers do this on 400+ inch motors.
This a 3.55" or 4" pulley? Going to try a Procharger race innercooler someday? Mine is making progress. Would be thrilled to just match these numbers. GJ man
Old Feb 6, 2015 | 12:59 PM
g8gt208scvette
4"...can't go any lower with this setup until I do a flip drive....belts were slipping. Billy told me this intercooler will hande ~2000hp So i'm not sure if I already have it or what but he said i'm good on that. The meth is def working pulling 17 degrees of timing!!! 70 degree charge air temp...54degrees after the meth
To Dyno was a success!
Old Feb 6, 2015 | 02:13 PM
RayT's Avatar
RayT
7th Gear
Awesome!
Old Feb 6, 2015 | 02:27 PM
Mike Farris
The procharger innercooler is good but a thicker "race" version came out about a month ago. White Lightning in the FI section had pretty good gains with it. Something like 100rwhp on a 1400RWHP F1X car.
An 8 or 10 rib flip drive will help. As would an A&A SC bracket. I'm hoping my 8 rib A&A will hold a 3.55" pulley.
Old Feb 7, 2015 | 02:05 AM
g8gt208scvette
I'm going to run out of fuel if I pulley and lower. My fuel system is already plumbed so I plan on just getting a bigger pump. Then doing the Dallas Performance bracket and flip drive with 3.55" pulley
