Calculating drag tire size's
Old Feb 6, 2015 | 11:12 AM
dentalfloss's Avatar
dentalfloss
Default Calculating drag tire size's
I went to the drag strip last fall with my stock 2005 coupe base with manual trans and GY runflats. I turned a 13.1 at 111 mph. (cold day, bald tires, bad 60'). I remember I used all of 3rd gear across the line. So now I am about to buy drag slicks 275/40/17. The GY are 26.9" diameter and the drag tires will be 25.6, I installed a performance cam, headers and a tune since and am thinking that with shorter tires and performance mods I will be running higher mph and will probably have to shift into 4 th right before the finish line which I think will not be a good thing. What are your opinions on this. here is the calculator system I used. http://xse.com/leres/z06/calculator.html
