ceaking/clunking suspention gremlin
Old Feb 11, 2015 | 09:04 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default ceaking/clunking suspention gremlin
I have phadt featherlight c/o's, joc bars w/ adjustable endlinks,lowered and I can't figure out where this noise is coming from.... I checked all mounting bolts/nuts, brand new endlinks, checked axle nuts (year ago and were good). sound is coming from rear drivers side as best I can tell...? thoughts?
* title edit * creaking/clunking suspension....damn auto text
Old Feb 11, 2015 | 12:31 PM
ErnieN85's Avatar
ErnieN85
last few times that happened to me it was the shocks.
first time brand new. second time old and worn out
Old Feb 11, 2015 | 07:49 PM
Boomer111's Avatar
Boomer111
Gotta throw this out, roof creaking?
I know you have been here long enough to know about this, but seems like you checked everything else.
End links can make their noise while going over speed bumps etc. smooth rode not so much.
Could be them even if bolts are tight.
Old Feb 13, 2015 | 02:32 AM
vetten76's Avatar
vetten76
I chased that one through three front end shops. It was the end links. Everything seemed perfect and tight. Out of desperation, I replaced the end links. I used stock parts on big sway bars. Replacement end links solved the clunking. They last one track day then start making noise again. I've read that all the aftermarket end links clunk.
Old Feb 13, 2015 | 09:17 AM
C U IN REARVEIW
i'm thinking that must be it... I just swapped out exhaust systems
(bassani-npp)so I guess I just notice it more now than before. I also get the roof creaking as well.......just need a good stereo I guess...lol
Old Feb 13, 2015 | 02:29 PM
ErnieN85's Avatar
ErnieN85
There is one aftermarket end link set that doesn't get noisy.
LG Racing (forum vendor)
His are PTFE lined
Old Feb 13, 2015 | 05:37 PM
theblue's Avatar
theblue
end links are my guess also. make sure you adjust and tighten with load on the suspension.
Old Feb 13, 2015 | 08:21 PM
C U IN REARVEIW
I did, I hooked up one side endlink put car on the ground a went around the block. lifted car back up and adjusted other endlink to length needed to connect to the swaybar.....??? does the second one need to be adjusted while car is sitting on its wheels...ie: four post lift?
Old Feb 14, 2015 | 11:55 AM
theblue's Avatar
theblue
all adjustments and tightening should happen with the full weight of the car on the wheels ideally otherwise when you put the car down the bushings can possibly rest in a stressed position which can kill them quicker.
Old Feb 14, 2015 | 06:58 PM
C U IN REARVEIW
I remember now that we did final adjustment on ramps. So should be good......
Old Apr 18, 2015 | 10:13 PM
C U IN REARVEIW
I seem to have narrowed the noise down to the actual travel of the shock (compression. Shock seems to still be working,but seems to not function smoothly. Are these oil or gas filled/charged?
Old Apr 19, 2015 | 09:08 PM
Vito.A's Avatar
Vito.A
It's been several years, but someone actually researched the source for the OEM shocks and they cost GM less than $10 each.
I replaced mine with Bilstein Sports and have been very happy with the ride and handling improvement.
Old Apr 19, 2015 | 10:31 PM
C U IN REARVEIW
I'm running coilovers on my car.
Old Apr 22, 2015 | 11:05 AM
Vito.A's Avatar
Vito.A
Are the springs binding on the shock body?
Old Apr 22, 2015 | 06:01 PM
C U IN REARVEIW
No, we checked that as well. It sounds like the shock is not operating smoothly (ie: a bad hood/hatch lift cylinder)
To ceaking/clunking suspention gremlin
