C6 differential inspection
Old Feb 14, 2015 | 08:56 AM
timd38's Avatar
timd38
Interesting, wonder if your son upgraded to an 06 or newer diff when RPM built it.
Old Feb 16, 2015 | 05:00 AM
rilloroc's Avatar
rilloroc
He said that was the rear that was there when he bought the car. I don't really know how to identify what's been done back there. I'm gonna call rpm and see if any of the markings on the case can help me to identify what stage it is. I would hate to replace it with one that's rated for lower power than this one
Old Feb 19, 2015 | 07:27 PM
rilloroc's Avatar
rilloroc
Originally Posted by Bill Curlee
If it were my car and I needed the rear or trans rebuit,, Heres where I woud send it to:
http://rktperformance.com/
Talk to Rick Kim. EXCELLENT Service
Call RKT Performance
5400 Yukon Court,
Suite 400
Frederick, Maryland 21703
Phone: 301.257.0930
I've decided to go with RKT. I'll be shipping it off this weekend.
Old Feb 20, 2015 | 01:25 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I hope you're not rebuilding the 05 case, the housings notoriously crack in half and the pinion shoots out the back. If your case is cracked (and if the ring gear stripped it likely is) be sure and check your transmission output shaft, they normally bend when this happens which requires a transmission rebuild.
Be sure and upgrade to a 06+ case (which requires a new transmission end plate) or a C5 rear which requires a cradle adapter that stanger383 can make you.
Rick Kim knows all of this so hopefully he's set you straight on it. He did these upgrades with a buddy local to him in MD with an 05 like mine.
Old Feb 20, 2015 | 08:53 PM
rilloroc's Avatar
rilloroc
It's been upgraded to the newer style. Rick explained to me over the phone how to tell. I pulled it today. From what I can see through the opening, this diff is brand new. The ring gear looks like it has no miles on it. The fluid, except for all the metal, looks fresh out the bottle. I don't really know corvettes, but it looks to me like less than 100 on this diff.
Old Feb 20, 2015 | 09:27 PM
rilloroc's Avatar
rilloroc
pics of my new baby
Old Feb 22, 2015 | 10:09 AM
timd38's Avatar
timd38
Originally Posted by rilloroc
Did you stay with 3:73 gear? I put 3:73 in mine and it appears to be just enough.
Old Feb 22, 2015 | 11:47 AM
rilloroc's Avatar
rilloroc
I haven't made any decisions yet. I was gonna wait until Rick tells me what's going on in there. What do you mean by just enough? The rear was chewed up when I got it so I don't really know what it pulls like.
Old Feb 22, 2015 | 12:40 PM
dev1360's Avatar
dev1360
I was worried about 4.11s with my M6. They are perfect. Highway cruising is a non issue.
I don't know why it's upside down. This app sucks.
Old Feb 22, 2015 | 01:28 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I have had 3:42, 3;90 and 4:10. I would always choose 4:10, more of what you are looking for. Makes the car feel 500 lbs lighter as you are giving it a longer lever to work with.
Old Feb 22, 2015 | 01:55 PM
rilloroc's Avatar
rilloroc
She's probably gonna see some racing with about a 50 or 60mph rolling start. How would a taller gear affect that?
Old Feb 22, 2015 | 02:06 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
My car is killer on a roll up to 138 which is my redline on 4th gear. I can beat cars with a lot more HP. You will learn to set the race so you can pull in third for a bit then hit fourth. That longer lever of 4:10's gives you an advantage over 3:42 cars up until you shift to fifth at 140 which you shouldn't be doing on the highway anyway.
Check out post 11 in this thread for a good explanation why.
https://www.corvetteforum.com/forums/c6-tech-performance/3049605-best-mod-for-return-on-dyno-overlay-stock-headers-cam-fast-heads.html
Old Feb 22, 2015 | 05:33 PM
  #33
timd38's Avatar
timd38
As you can see, a large number of people like 4:10 gears. I picked 3:73 as a compromise all around ratio.
Just my opinion, and I am not going to debate why it is better than the 4:10 gears or not because it is what I wanted and I only need to satisfy one person, me!
Old Feb 22, 2015 | 05:57 PM
  #34
dev1360's Avatar
dev1360
Here's a crappy quality video with lots of spinning and slow shifting lol.
4.10s, and a cam. LS3.
Old Mar 13, 2015 | 10:15 PM
  #35
rilloroc's Avatar
rilloroc
I forgot to update. I had never shipped anything like that before and I was scared it would get damaged during shipping so i built a box. It's really a cradle with the diff bolted to it and a cover.
When Rick received it he found that the gears were fine but the carrier assembly had blown all to crap.
Rick rebuilt it in a day and shipped it back to me. Took me about 2.5 hours to get it back together and I've been cheesing every since. I kept the 3.73's since the gears were good. New carrier and seals and everything else.
