DD cammed?
Old Feb 13, 2015 | 11:56 PM
ignatkor's Avatar
ignatkor
Default DD cammed?
I really wan to get my 09 m6 coupe cammed, but even after days of researching and searching this forum I am still unsure. I have to drive at least 3 days a week, 80 mile round trip to work but I want more power and that cammed sound sooo bad I can't stand it anymore!!!! What cam would you recommend? anyone DD with a cam?
Old Feb 14, 2015 | 02:13 AM
winters97gt's Avatar
winters97gt
ECS, Brian Tooley, Pat G, and Arun all have great cam specs. Talk to them and have a custom cam specd for exactly what you do with your car.
Old Feb 14, 2015 | 08:07 AM
Kip Fabre's Avatar
Kip Fabre
I DD a 2010 M6 call me I can make you one you will like if it's to big it will not be any fun to drive. Kip@ Cam Motion
Old Feb 14, 2015 | 09:30 AM
old motorhead's Avatar
old motorhead
Yeah, finding a cam that's big enough to do some good and small enough not to have "issues" is a tough call. Plus one guy's too big is another guy's too small. My blower cam is a 224/234 116+2. I wouldn't want to go any bigger for a DD. I have "0" tolerance for big cam issues though. You may not mind "shifting around" some of the big cam issues. Not for me. Problem is that my cam a 460-470 rwhp cam without a blower. With 9.5psi, it's a 664rwhp cam though
Are you totally against adding a blower? Best of all worlds for a DD.
Sorry for being "that guy". But it's a Corvette Forum rule that at least one of us blower guys has to jump on a cam thread and recommend a blower. It is what it is....
Old Feb 14, 2015 | 10:56 AM
theblue's Avatar
theblue
what sort of issues are you talking about needing to shift around? It's in my plans to add a mild to mediumly aggressive cam for street and maybe a bit of tracks days/drag racing. I'm curious about what downsides I will dislike. (my car is a manual) will I still be able to cruise on the highway in 6th smoothly at low rpm?
Old Feb 14, 2015 | 12:49 PM
Pitufina's Avatar
Pitufina
If you have never been in a cammed car it would be hard to explain. Basically a good dd cam depends on the aggresiveness of the lobes ramp rate, duration, lobe separation angle, etc. Also what is your tolerance of what is too much or too little. The best advice is to talk to a cam spec guru and tell them exactly what you want and how you want it to behave. Clearly a good tuner comes into the equation as well. A cam that is too big for the average guy will buck and surge at low rpms below 2k and typically around 1.4k. The work around is to downshift and keep it above those rpms. Hope that helps.
Old Feb 14, 2015 | 02:26 PM
old motorhead
Pitufina put it pretty well. Overlap is what you need to look closely at as far as I'm concerned. I've had a +9, a +2.5, -3 (current cam), and several more in the negatives. With the +9 overlap cam, I could tell if I was going against or with the wind. Against the wind, cruising at 60 in sixth gear was OK. Cruising with the wind, I'd shift to 5th because of the surging. Also, you see less than perfect manners going up and down hills in 6th. The +2.5 o/l cam wasn't as bad, but it still had a few low rpm issues. The -3 and smaller cams had pretty much stock like manners.
Again, it's a personal preference thing. Some don't mind that stuff at all. A spot on tune sure helps, but won't totally eliminate issues with a higher overlap cam. That's been my experience anyway.
Old Feb 14, 2015 | 04:28 PM
dennis50nj's Avatar
dennis50nj
I would ask these guys Cartek, they picked my cam perfectly for DD and this car was an LS3 and ran that time a long time ago without a bunch of bolt/ons supporting the H&C also it was a FULL WEIGHT C6 with no skinnies drag pack no tricks both seats driven to the track on pump 93 octane even the rims with the dragradials were very heavy, I'm sure LS1LT1 remembers what they were. in my opinion this certainly would have been the fastest LS3 MANUAL C6 if a drag person finished it for the 1/4
Originally Posted by Max@Cartek
Can I get on the list?
- Year Corvette: 2008
- Type of Trans: Six speed manual
- Type of Suspension: Stock
- Tires utilized: ET Streets
- Modifications: Cartek stage 4X H&C package on a LS3, stock bottom end.
- Dyno numbers: 515 RWHP, 459 RWTQ
- Time slip:
___ Atco
___ 12/03/2008
___ 60'.............1.495
___ 330'...........4.450
___ 660'...........6.848
___ 660’ mph....101.69
___ 1000'.........8.914
___ 1320'.........10.633
___ 1320’ mph…132.44
I attached an image of the slip.
Thanks,
Max
Old Feb 14, 2015 | 05:37 PM
berk4422's Avatar
berk4422
I've always been curious if there is a formula for identifying the right size cam for each scenario. Everyone has different goals and cams come in all sizes to meet those goals. Just curious, on a scale of 1 to 10, 10 being most important, how would you rate these items?
  1. Daily Driveability
  2. Sound / lope
  3. Power Gain
  4. More Pwr/Tq <5000 RPM
  5. More Pwr/Tq to Redline
  6. 1/4 mile times
  7. Road race lap times
  8. Autocross lap times
Old Feb 14, 2015 | 06:41 PM
C6z06man's Avatar
C6z06man
Just stick with something mild and get it tuned by a knowledgeable/patient tuner. You'll be fine.
Old Feb 14, 2015 | 08:13 PM
tennblkc6's Avatar
tennblkc6
whatever you do don't just buy an off the shelf can unless it has been recommended by a cam guru that knows what you're looking for.
don't cheap out...do it once and be done with it.
Old Feb 14, 2015 | 10:23 PM
dev1360's Avatar
dev1360
I have a custom PatG cam. With 10* of overlap, and and very good tuner (DSteck), I drive my 09 M6 daily with comfort.
Specs and times in sig.
To DD cammed?
