stage 3 clutch question
That cultch is a little more grabby than stock but since you have little/no experience with a stock C6 clutch you wont notice. It's also lighter so it will rev quicker. When you get the car find a safe place where you wont hit anything if you lurch forward. Start the car, put it in 1st gear, and slowly start to let your foot off the clutch. Stop just before you feel it starting to stall. That's a good way to learn the travel and engagement point. Then find an empty parking lot and practice your takeoffs and 1st - 2nd shifts. Spend some time getting used to it. If you have a safe area with a secluded incline, try simulating being stopped in traffic or at a light/stop sign while on a hill. Learn how much gas you need to give it without rolling back, stalling, or doing an accidental burnout. Also, something most people don't think about, practice reverse. Since you're generally not going very fast backwards, reversing can be a little jerky with that clutch. Once the basics are down then you can practice highway downshifts, high RPM launches, heel-toe, etc.
Overall it's not a bad clutch. It holds the power, revs quicker, and you can get used to it for daily commuting. Keep in mind, you will stall, you will buck, and you will unintentionally chirp the tires until you get used to it. But that's the fun in learning.
Also, if you are buying this as a DD, then how drivable is the car in traffic? Is it almost imposable with the motor surging and clutch grab/chatter or not?
