B&B PRT s
the vendor couldn t help me much, suggested i call B&B, i did, and the customer service guy, Mike, must be having a bad day, i explain what i have and he starts cursing and swearing. Terrible representative of the company. the drone on these is deadly, he said impossible. My qurestion is, does anyone have drone with these ??
i will have to look at other options.
The car is pretty loud when I want it to be, but there's no drone on the highway unless I'm at high load in high gear (like, accelerating up a hill in 6th). Even then, I don't consider it to be unpleasant.
When you say "drone", do you mean cruising on the highway, low load (flat road, constant speed, low throttle, not accelerating)? that's where I define drone to exist. Anywhere besides that and, to me, it's desirable engine noise that I want to be able to have loud.
Now, the automatic transmission produces some interesting sound harmonics due to the torque converter, shift points, and being able to shift with throttle applied. Because of this, my system should be even louder than yours. And still nothing I would consider drone. Yeah, it's a good bit louder than stock, but nothing about it is unpleasant. It's not really any more noticeable (to me) on the highway than the stock setup.
The PRT system was designed specifically to eliminate drone. Similar to Corsa's setup, from what I understand, except they flow better when you get into modified motors (heads, cam, FI, etc). On a nearly stock motor, you shouldn't have any drone. I don't expect to experience any drone after I throw a cam in the car, either. Are you positive that yours is a PRT system and not the bullets? That's the only thing I can think of, short of a damaged or defective muffler.
Just my opinion/experiences.
thanks for your thoughts.
Good lucky, love my B&B exhaust. Seems like everyone has a Corsa, and I like to be different.
Beast
Beast
