Will these wheels work
Old Mar 5, 2015 | 11:27 AM
C6vettegfw's Avatar
C6vettegfw
Default Will these wheels work
Hey guys my wide body kit is on the way. I just ordered the zr1 replica wheels. I got 19x12 for the rear and the fronts are 18x9.5 with 57mm offset. Will that wheel work on the car it's a 2006 base model c6 I know the rear is fine but what about the front. Thanks guys.
Old Mar 5, 2015 | 12:30 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Should fit perfectly.
Old Mar 5, 2015 | 12:32 PM
C6vettegfw's Avatar
C6vettegfw
Even though the front is staying stock?? Only the rear is wide body
Old Mar 5, 2015 | 12:35 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I am only referring to the fronts. I had 9.5 x 53 which were right to the edge of the fender. 9.5 x 57 should retract by 4mm.. so should be perfect.
Old Mar 5, 2015 | 12:37 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
these were 9.5 x 53 offset...
Old Mar 5, 2015 | 12:41 PM
C6vettegfw's Avatar
C6vettegfw
awesome thanks man
Old Mar 5, 2015 | 12:43 PM
C6vettegfw's Avatar
C6vettegfw
Are you a Canadian as well?? I just noticed your username
To Will these wheels work
