Is this LS7 block salvageable ( Lifter bores)
Old Mar 7, 2015 | 10:57 AM
brandon1566's Avatar
brandon1566
Default Is this LS7 block salvageable ( Lifter bores)
the Third picture I am not sure if its chipped or cracked. Is it sleevable?
Old Mar 7, 2015 | 07:19 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Hard to say from the pic. Can you borrow or rent a bore scope for a better look?
Old Mar 7, 2015 | 07:44 PM
GMJim's Avatar
GMJim
A machine shop can re sleeve the lifter bores. I've done this (machine shop) a few times.
Old Mar 7, 2015 | 08:20 PM
brandon1566
I may have answered my own question when I pulled the crank and pistons out. A lifter when came off and partially imbedded itself into the block. The bottom of the lifter bore on the number 3 picture is pretty bad looking.
Old Mar 7, 2015 | 09:51 PM
C6z06man's Avatar
C6z06man
Should be sleeve able. Could try to hand sand it and then measure the clearance and check it to spec. I do this on over head cam engines all the time. On the cam journal.
To Is this LS7 block salvageable ( Lifter bores)
