I broke my throttle actuator plug in on my C6 Z06, how does one replace the end piece only? Please see pic below, its the green plug in part that plugs into the throttle body (not actually the plug from my car but illustrates what I am talking about). I could take in to a GM dealer but they will soak me. Thanks in advance.
GM/racetronix sells a connector with wires that you can cut the wires off the old plug and connect to the new connector wires, or you can use a pick tool to remove the wire connector from the old plug and just snap them back into a new connector plug instead.
Thanks Dano523, i would like to snap the wires back into an new connector plug. I appreciate the insight on this thank you Dano523! And thnx Forum.
Originally Posted by Dano523
How do you want to attack the problem.
Thanks for the info, i wished i would have seen this yesterday, i bought one locally from GM, it was 60.00 dollars ! No wonder GM is showing record profits these days.
