I am going from FI to NA and need to buy a CAI and MAF. I am only shooting for 500ish rwhp. My question is do I just get a stock ls2 MAF with a good CAI (open to suggestions) or something like a LPE, ABACO, etc MAF?
Note that I have ported ls3 heads, TB and intake. Custom cam, 1 7/8 LTH w/ no cats
thanks
Chances are your MAP is set up 2 bar now for the FI, and will need to go back to single bar MAP tune.
Talk to your tuner since this will need to be changed in the tune.
Also would help to know that motor, and even what CAI, since the Vararam CAI intake already comes with a over size MAF for the LS-2, and some of the later model vet CAI use the later model Vet's side mount MAF don't have the restriction problems as the LS-2 inline MAF's instead.
was running a 3 bar SD tune and I've already switched back, hence why now looking for a MAF
it is an 06 l2 with mods posted in first post. thought about the vararam but not sure if it would interfere with an oil cooler if I mount one in front?
what size is the stock MAF?
Originally Posted by Dano523
Chances are your MAF is set up 2 bar now for the FI, and will need to go back to single bar MAF tune.
"Chances are your MAF is set up 2 bar now for the FI, and will need to go back to single bar MAF tune."
2 bar is good to 200kpa so depending on altitude it can be 14.7 or higher or lower (maybe not lower as that is sea level I believe) but yes that is a good rule of thumb.
I was close to maxing out the sensor which causes issues so installed 3 bar and ran a 2.5 COS
A 2bar map sensor will measure up to 14.7psi of boost, while a 3bar map will measure up to 29PSI of boost instead. [/QUOTE]
2 reasons. I have a TT car making more than that and I have an awful disease known as a fool with his money
