Lowering bolts
Old Mar 15, 2015 | 09:40 PM
Blairj24's Avatar
Blairj24
Default Lowering bolts
I've lowered my car in the rear all the way down to rubber bushings. I want to go lower and in order to do that I would have to cut the bushing in half or take it out completely. I race my car at the track. Will I suffer from wheel hop doing this to the rubber ?
Old Mar 16, 2015 | 02:57 PM
Homer3D's Avatar
Homer3D
You can cut the bushing but I would not remove them completely. You will just end up with the leaf spring rubbing against the control arm.
If you really do race your car at the track, I would suggest you upgrade to coilovers.
Old Mar 16, 2015 | 06:20 PM
timd38's Avatar
timd38
Ditto.
To Lowering bolts
