spastic window
Old Mar 24, 2015 | 11:40 AM
otisfooter's Avatar
otisfooter
Default spastic window
Just today my drivers side window won't index correctly, tried to re index with switch as in the manual, but I don't know if this only works after battery disconnect, did not want to do that if not required. The window drops like normal then when I close the door it cycles about 10 times before it stops. any help thanks.
Old Mar 24, 2015 | 01:25 PM
cclive's Avatar
cclive
Here's text from a GM service bulletin...note the words "continuous up and down":
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)Models: 2007-2008 Cadillac XLR2007-2008 Chevrolet Corvette ________________________________________ ____________________________________This bulletin is being updated to end the need for diagnostic information and to provide field fix information. Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).___________________________ _____________ ___________________________________Condi tionSome customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.CorrectionDiagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested back through the Warranty Parts Center return process.Parts Information Part Number Description10446243 Front Side Door Handle SwitchWarranty InformationFor vehicles repaired under warranty, use: Labor Operation Description Labor TimeN9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide. "
Cleaning the door pad contacts is easy and would be my first thing to try. This issue is especially common in areas of high humidity.
Old Mar 24, 2015 | 03:17 PM
otisfooter's Avatar
otisfooter
thanks this is the kind of reply i was hoping for, something I can do myself. Thank you for the help.
Old Mar 24, 2015 | 04:31 PM
cclive's Avatar
cclive
The pads come off with a couple of screws and then are easily disassembled...just be careful not to let the wiring harness fall back into the door...this could add much complication.
Old Mar 25, 2015 | 03:29 PM
otisfooter's Avatar
otisfooter
Default spaztic window
A big thanks to cclive 15 min did both sides works perfect.
I would sugest anybody with a C6 more than 4 or 5 years old do this as a preventive measure, it is that easy. My passenger side was not acting up but was all corosion when I took it apart.
Old Mar 26, 2015 | 12:02 PM
cclive's Avatar
cclive
Glad to hear that it worked out. Usually this is something that only happens in humid places...but I'm still mystified as to why these contacts get corroded and yet other switches in the car are fine....weird. I also think you are better off cleaning them as you did rather than buying new ones because you can put a bit of something like WD-40 on the contacts to keep them from corroding in the future.
Old Mar 29, 2015 | 07:45 PM
Mluzzy1's Avatar
Mluzzy1
When I got my C6 this was one of the first issues I encountered. Came here and read the same advice. I had ordered new ones but just reinstalled the old ones and they've worked fine every since. Love this place!
To spastic window
