Boosted LS3---valve seal issues
Old Mar 25, 2015 | 10:34 PM
Slp0327's Avatar
Slp0327
Default Boosted LS3---valve seal issues
Hey guys I need some help..... I've got a Paxton 2200sl/cam and full bolt ons and 815rwhp on 93oct. gas.....I have needed to replace 3 valve seals within 800 miles of build....now it seems I need to replace more if not the same (car goes to shop tomorrow)
Is it normal? Is their a solution to keep it from happening?
Any recommendations would help. Thanks!
Old Mar 26, 2015 | 01:20 PM
irok's Avatar
irok
Default difference
the intake and exhaust seals are different.did you mix them up during install or not get proper seals
Old Mar 26, 2015 | 01:24 PM
Slp0327's Avatar
Slp0327
I hope my tech didn't....I switched techs so hopefully the new guy will find the problem and check the seals. Thanks for the help.
Old Mar 30, 2015 | 06:24 PM
Dealripper's Avatar
Dealripper
Default Valve Seal Issues
I run a 2200 S/L on a built engine by ECS. I am at 867 RWHP I have not had any problems with my valve seals. Hope you get it sorted out.
Old Mar 30, 2015 | 07:52 PM
C6z06man's Avatar
C6z06man
What seals are you running? Stock or aftermarket?
Old Mar 30, 2015 | 10:41 PM
Cor430vette's Avatar
Cor430vette
Others in your engine always means problems. Their attention to detail which is paramount just does not exist. They always mess something up. I hope this isn't the case with yours.
By the way, did they upgrade your springs, retainers and seals? They didn't leave the stock stuff did they? I would think with a blower and cam that the lift etc. would warrant the upgrade...??
To Boosted LS3---valve seal issues
