Shock question
Old Apr 6, 2015 | 06:46 PM
shawnaj7731's Avatar
shawnaj7731
Default Shock question
I am just curious, is there a difference between c6 z51 shocks compared to c6 z06 shocks? If so how much difference is there on a Weekend Driver with a once in a while drag pass. Is it worth the it to change over or not.
Old Apr 6, 2015 | 07:06 PM
RicK T's Avatar
RicK T
Pretty big difference. Z06 shocks are quite a bit stiffer. Most don't bother with them though, unless you get them for free or close to it.
If you want a better shock experience, the majority here go with Bilstein Sports or Koni FSD's. If you want a slightly softer ride the recommendation is Bilstein HD's.
Old Apr 6, 2015 | 07:26 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd agree that the Z51 are not as stiff as the Z06 shocks. Do you have a Z51 currently?
Old Apr 6, 2015 | 07:27 PM
timd38's Avatar
timd38
Ditto.
Old Apr 6, 2015 | 09:37 PM
Boomer111's Avatar
Boomer111
+ 1 for the Koni FSD'd, they are a bit pricey though as compared to the others mentioned..
Old Apr 6, 2015 | 11:57 PM
shawnaj7731
i do currently have a z51.. 90k plus mile not sure when they were replaced bought the car about a year ago..
Old Apr 7, 2015 | 12:16 PM
cclive's Avatar
cclive
100%. Oem shocks, whether base, Z51 or Z06 are essentially throw away items. If you are going to spend any money, get something better as stated above.
Old Apr 7, 2015 | 02:05 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
It also could be that they're originals. How long do you expect to keep it?
Old Apr 8, 2015 | 02:29 PM
CMY SIX's Avatar
CMY SIX
**** the stock shocks, don't waste the $ Bilsteins baby! shockwarehose.com should be able to get a set around $300 look around
To Shock question
