Base Coupe Differential Case Options?
I need a stronger case, but I'd like to stick with 4.11 gears. I know the base gears are smaller, but what is involved in fitting them into a Z06 case? I know the Z case is physically larger, but does it offer more strength?
I may just have to go with a Z06 diff in 3.42 ratio and add more power.
I do my own diff building, so won't be sending it off. They are on the list to call, but just trying to gather as much info as I can to make an informed decision.
This case is an 06 case. No damage to any of the working parts on either. Just broke the case internally.
RPM told me this is common when I talked to them. By the nature of the design, the ring gear tries to force the pinion rearward stressing the case in that area. 1.5x 60 times provide the necessary force.
People break with them, people break without them. Hard to say for sure.
Here is what ECS says. It is much different than DTE. If I remember correctly, the DTE only has two struts vs 4 for the ECS.
Why would you want or need a ECS Trans / Rear Brace?
Ever launch your Corvette hard, and it feels like the wheels are hopping? That wheel hop is actually the Drive line of your Corvette Shaking. In the C5 and C6 Corvette the transmission essentially “floats” in the driveline. It is not mounted to the chassis whatsoever. The Engine is mounted to the front cradle via the engine mounts and the rear end to the rear chassis. Both Factory mounts are rubber, and allow a certain amount of movement – especially under hard launches. This movement is felt, and usually explained as wheel hop and it can do some serious damage to your car!
So what does a ECS Trans Brace Do?
The ECS Trans / Rear Brace gives added rigidity to the entire driveline by tying the trans and rear together as a complete, more rigid unit. The ECS Trans Brace is made from top quality materials. Front and rear mounts are fabricated from laser coated, zinc coated steel with stainless steel hardware and aluminum tension rods to ensure a long lasting, rust free finish. The tension rods are turned from billet aluminum with high quality stainless steel heim joints with stainless steel hardware. The aluminum rod design provides increased strength, with heat expansion principles that match that of the aluminum transmission and differential.
I already have a 30 spline output shaft. I upgraded that with the last diff.
