Proper air pressure.
Old Apr 16, 2015 | 03:49 PM
One Kick's Avatar
One Kick
Default Proper air pressure.
Last week the 10 year old tps units in my 05 were replaced with oem units. I set the air pressure at 30 psi, (Firestone Firehawks run flats). Today I took the car out for a 30 mile check run, tie pressures stabilized at 35 psi in all four wheels. I don't recall seeing that type of increase before, maybe from 30 to 32 psi. 35 psi is a bit stiff in a car with the Z51 suspension to start with. Should I reduce pressure to 28 cold and see what I get when they heat up or just leave alone.
Old Apr 16, 2015 | 04:07 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I would do what your tire wear tells you to do to be honest.
Old Apr 16, 2015 | 10:52 PM
Boomer111's Avatar
Boomer111
In my experience 30 cold goes to 35 with normal highway driving with tempetures above say 65*.
As mentioned tire wear is the truth of the matter regarding just what the air pressure is doing regarding tire patch contact with the road.
I ran 30 hot for awhile and experienced some accelerated wear at both inside and outer edges. i do not think running 28 cold will do much harm and seeing if the ride is more desirable I would go for it. Just check for additional edge wear. I was running 26-27 cold in the summer and seeing 30-31 hot.
Going to non run flat tire's will be benifical too in aiding a softer ride.
Z51 and GY RF's I found to be way to harsh also.
Old Apr 17, 2015 | 11:49 AM
One Kick's Avatar
One Kick
I think I'll leave it at 30 and keep an eye on the tire wear as recommended. I don't put a lot of miles on the car so it will be probably a while before I see any wear.
Old Apr 17, 2015 | 12:11 PM
CMY SIX's Avatar
CMY SIX
get rid of the "run craps" and put a real tire on it and you won't believe the handling or the ride, 30 psi cold and don't worry about it! I'm runnig Kumho's and the have bee a VERY GOOD tire 320 wear rating, put a set on my mothers car{honda fit} and they have been exellent also!
Old Apr 17, 2015 | 07:49 PM
cclive's Avatar
cclive
Brand new tires are going to generate a bit more heat until they get broken in. Cold pressure is what's important (30), don't worry about the hot.
Old Apr 18, 2015 | 02:36 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
I also ditched the run craps, a much better ride.
Old Apr 18, 2015 | 10:46 PM
One Kick's Avatar
One Kick
Can't ditch them, too much money invested in them, besides it would be just my luck to get a flat. I have had a number of vettes and this one rides the best by far. I was just concerned about the tp increase when hot, Based on responses it doesn't seem like a big deal. I just don't recall the pressures prior to the tpms change.
To Proper air pressure.
