2006 C6... MS4 cam. PAC .650's... Texas Speed setup, installed by a reputable shop here in Houston. 5000 miles on the setup. Never overreved the motor since I took possession a month ago...
Ouch.
Fingers crossed no bent valves. Replacing springs on Saturday, leakdown test following install.
Wow, now i see the top spring perch broke, that spring went solid for enough force to break that, damn. Unlees the failed spring made the spring taller and the impacted the top spring perch.
It looks like you have more than one failed spring.
The seals and retainers are also damaged in those pictures. I think there is more to the story than bad valve springs. Brian Tooley springs have a good reputation from what I have heard.
x2
I'm running BTR's full setup in my heads. Every shop I've ever spoken to recommends them.
Magic Stick 4 is a very big cam.
I'm open to suggestions. I have another set of .650's from tooley. And then I can go ahead and get the PAC .675's and swap out later. Just want to get the car running. Amd/ot check for a bent valve
indeed valve seals first pic you can see the upper ring,
The MS4 is .649".. I'd be putting in .675" than upgrading to .700" as a safety precaution. I'd never run a .650".
