strange constant misfire
Old May 1, 2015 | 01:44 PM
koji77's Avatar
koji77
Default strange constant misfire
Guys,
need your help on this one. I was driving home in my 05 LS2 C6... going about 75 then all of the sudden she started running like ****.. misfiring.. I limped her home (20mph). I've changed the plugs and plug wires.. still running like **** and indicating misfire.
I've got no codes to indicate a coil pack issue only the p0300 (what ever it is) misfire code along with U2100 (which I don't believe has anything to do with the issue (or does it).
Any help appreciated.... I would assume if it was a cam position sensor or a crank position sensor it would throw a specific code for that.
Again, thanks for any help ya'll can give me!
Old May 1, 2015 | 04:43 PM
HK770's Avatar
HK770
https://www.google.com/webhp?sourcei...=UTF-8#q=p0300
https://www.google.com/webhp?sourcei...vid=1456804596
Old May 1, 2015 | 09:01 PM
truckplay's Avatar
truckplay
u codes are communication codes. p0300 is a multiple cylinder misfire. have you had the headlight recall done ? you may have something loose in the under hood fuse box. could you have gotten the fuse box wet ? how about the one under the passenger floor ? if the computer is loosing signal, that would explain the codes. I would start by checking battery cables and their connections 1st. then check the cam, (it is behind the water pump & has 2 connections ( 8" extension) and crank sensor (next to the starter) then check fuel injector harnesses, fuel pressure and compression.
Old May 1, 2015 | 09:14 PM
koji77's Avatar
koji77
this is a C6 no flip up's. car was running fine then all went to crap.
Help!!
Old May 1, 2015 | 09:26 PM
truckplay's Avatar
truckplay
Help!!
the headlight recall is on the C6,it gets done at the under hood fuse box. it has to be split and a jumper installed. the fuel pump relay is there ecm power comes from there also.
Old May 1, 2015 | 09:57 PM
koji77's Avatar
koji77
Okay ... did not know that.. do you think this is my issue based on what I have presented?
Old May 2, 2015 | 07:25 PM
truckplay's Avatar
truckplay
you need to check things 1 at a time.
Old May 9, 2015 | 08:12 PM
koji77's Avatar
koji77
I'll check and let you know what I find... thanks!!!
Old May 9, 2015 | 11:17 PM
Wampa's Avatar
Wampa
sure its random misfire or specific cylinder? I wouldn't rule out individual coil unless it's a multiple misfire code.
Old Aug 7, 2015 | 01:34 PM
koji77's Avatar
koji77
Default help
I will be going over all you have stated this weekend. I hope it's simple. Once the car warms a little it lines right out. Mis fires when 1st cold start primarily. I appreciate your help and guidance.
Old Aug 7, 2015 | 01:35 PM
koji77's Avatar
koji77
She is not throwing any code... just the flashing engine symbol indicating multi mis fire
To strange constant misfire
