frame problems
Old May 8, 2015 | 09:21 AM
ERIC_MEMS1@YAHOO.COM's Avatar
Default frame problems
how difficult is it to cut and weld in a partial frame rail on a c6 vert ?
Old May 8, 2015 | 09:28 AM
c5racr1's Avatar
c5racr1
Default frame
as long as you get on a good rack it's no problem. In the past I found it easier to replace the entire rail and square it up. If you just want to do a section get the frame alignment specks and put it on a frame rack take the measurements and do the job. If you are not familiar with doing this find a real good body shop to do it, if they get it wrong it will cause u a lifetime of PITA getting alignments and rattles.
