Should I be adding anything before a tune?
Old May 12, 2015 | 07:46 AM
slayer6x6's Avatar
slayer6x6
Default Should I be adding anything before a tune?
Just finished up a cam swap, among other things and I have an appointment to get a dyno tune next Thursday. I'd like to get an opinion from a few people if I should be adding any more supporting mods before the tune. Heres a quick list of the mods currently on the car.
Vararam
Fast 102
TSP torquer v4
Kooks headers/x pipe
BB rt106 catback
Are the stock TB and injectors worth the bank for the buck at this point or should I just let it be?
Old May 12, 2015 | 12:15 PM
dmoneychris's Avatar
dmoneychris
Vararam
Fast 102
TSP torquer v4
BB rt106 catback
Some people have mentioned to change out the spark plugs & go w/a slightly colder heat range, even though they don't need to be changed...It might be something to consider. I would do so more research because I'm no expert. I bought NGK Iridium TR6 IX upon recommendation from the guy that will be installing my ARH LT's, X-pipe & Akrapovic slip on exhaust.
Old May 12, 2015 | 02:01 PM
vet55's Avatar
vet55
Subscribed for Dyno.
Old May 12, 2015 | 02:08 PM
PatientZero's Avatar
PatientZero
I would also like to see this dyno
Old May 14, 2015 | 07:20 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
did you change the Thermostat?
Old May 14, 2015 | 08:46 PM
slayer6x6's Avatar
slayer6x6
I did not do the thermostat...
Old May 14, 2015 | 09:02 PM
Suds's Avatar
Suds
Yes, so the other common mods at this point, would be colder plugs, colder thermostat and an under drive crank pulley.
Old May 14, 2015 | 09:10 PM
Boomer111's Avatar
Boomer111
If you love in a cold climate you will never get the oil up to proper temp with the 160* stat in the Winter.
In sunny California with mild Winters my car a hard time getting above 170* oil temp. Some go with it but I feel this to be a tad low.
Coolant would be hard pressed to reach 212* also. Burning off any water present.
Old May 15, 2015 | 01:39 PM
Cherokee Nation's Avatar
Cherokee Nation
The shop that did my mods put in a 180 stat & I still have to drive it for awhile to even get the oil temp to 210*..
Old May 18, 2015 | 12:25 AM
Vito.A's Avatar
Vito.A
Make sure you have the best fuel available in your area. If your car has been sitting all winter I would use up that fuel. Also, we are right in the middle of the EPA mandated winter-summer blend change over (summer has lower RVP).
Old May 18, 2015 | 02:38 AM
AaronLS3's Avatar
AaronLS3
Default tune
Tr6s and 160 t-stat. Make them able to pull a Lil more timing.
Old May 18, 2015 | 08:50 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Throttle body is fine.
Injectors will be nearly maxed out, but I've had no problems with similar mods with my stock injectors, they are "maxed out" 90% + but they work fine and i can command any AFR I want.
In my observations, drivability can suffer when people change out their injectors; there are tables to convert the tune for different injectors but I'm not sure those are always correct, and some injectors are easier to tune than others.
Old May 18, 2015 | 10:30 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
If this is a daily driver in Pa. you don't need anything else. Believe me, I have all the things mentioned so far.
Old May 18, 2015 | 10:36 AM
slayer6x6's Avatar
slayer6x6
Thank you for the replies and suggestions.
The car is not a daily, if it follows in the footsteps of its predecessor (2000 SS) it will see <1000 miles a year.
Old Jun 22, 2015 | 11:00 AM
JimiHendrix's Avatar
JimiHendrix
Default Updates
How is that Torquer V4 cam working out? Any Dynos? I am considering this over the LG G6X3. They want over 600.00 for their cam and I am wondering if it is worth it?
Old Jun 22, 2015 | 12:38 PM
zali0104's Avatar
zali0104
Besides making sure everything is in reliable working condition, cooling system etc. Take the car in as you would drive it every day. New plugs are nice but give a false reading on the dyno. New plugs usually add about 5+ hp but that goes away in a few miles. Use the fuel that you always use unless doing a separate tune for a higher octane fuel. Some tuners recommend removing your air filter. this can pick up 10-15 hp at higher rpms. This is not a real world condition, avoid. A lot of people forget this but check your rear tire pressures, under inflation can rob you a few hp.
Walk with several bags of ice to prevent or at least minimize heat soak between dyno runs. The fans they hace hardly duplicate the air flow at highway speeds. A fresh oil change cannot hurt. Dyno tuning is hard on your oil. especially on absorption style dynos.
You mentioned your oil takes awhile to reach operating .temperature, correct this situation. The faster oil gets to operating temperature the better. Adding an oil to coolant heat exchanger between your external oil cooler makes the oil temperature rise with coolant temp.
Good luck.
To Should I be adding anything before a tune?
