Spark plug heat range
Are you having any problems with it missing now? I would only go hotter if you're having problems with fouling
6's with a 175 shot doesn't sound like a good idea to me
Any gain in power derived from spark plugs would come through uniform, optimal combustion within each cylinder.
To achieve maximum performance / power, the proper heat range is determined by inspecting the tip of your used spark plugs collectively. Each plug tells a story.
As a rule of thumb - they should all be burning the color of hot cocoa (light brown).
If one or more plug were darker or covered with residue, indicating it is fouled with oil, it is robbing your engines power and efficiency and a hotter plug would be beneficial to burn off those deposits.
Likewise, if one or more plus are lighter in color or the tip is burned away, then a colder plug is required to maintain the proper gap and minimize further damages.
Happy trails!
