Paddle Shift Indicator Problem
Old May 28, 2015 | 08:35 PM
carsangelop's Avatar
carsangelop
Default Paddle Shift Indicator Problem
I posted this in the general section and didnt get to much response
2012 GS Vert Auto When using the paddles the indicator on the DIC never
changes from M1 no matter what gear I up shift to or down shift to
However the indicator in the HUD does change as I go through the gears.I have tried it in every mode
The trans works fine no problem there its just the indicator in the DIC
that never changes from M1 no matter what Even in reverse on neutral
M1 shows in DIC
One other thing that may be related when I have XM on and shut down
on start up the XM station defaults to station 1
This all started after 1st start up after winter lay up.Had a battery tender on all winter I did take off the negative battery cable for about
20 minutes and no change
Any ideas/ Thanks
