Nav Master PIN
Old Jun 3, 2015 | 12:55 PM
range96's Avatar
range96
Default Nav Master PIN
Read in the How to section about "Hacking the NAV screen Diag PIN code". It requires a System master PIN code, supposedly listed in the owners manual. I looked for it everywhere. Can't find it. Can someone point me to it?
Old Jun 3, 2015 | 01:41 PM
EVRose's Avatar
EVRose
I think you need a tech 2 to get in there.
Old Jun 3, 2015 | 03:24 PM
Kent1999's Avatar
Kent1999
You can stop looking. I think whoever wrote that about the PIN is confused. There is no master pin code listed in the owners manual.
I haven't even seen anything about it in the factory service manuals, nor would there NEED to be. The only Nav radio configuration needed is the VIN relearn (and many at the dealership struggle even with that simple function). No hacking or changing of Nav Radio operational parameters is allowed or encouraged at the dealership level.
Old Jun 3, 2015 | 05:09 PM
EVRose's Avatar
EVRose
Ok, after some simple searching I found that you can in fact access a hidden menu and enter a pin code. There is not much you can do after your in there but HERE is a good thread all about it.
Old Jun 4, 2015 | 11:18 AM
range96's Avatar
range96
Thanks for confirming my suspicion.
Old Jun 4, 2015 | 11:21 AM
range96's Avatar
range96
Thanks for the link, it explained a lot.
Unfortunately, after paying high price for an inferior built-in navigation system, we have limited use of it.
To Nav Master PIN
