Brakes Pulsating
Now - the rotor turning process typically involves two cuts on each face. Both faces are cut simultaneously - (so there isn't a lot of force being transferred through the thinner web to the bolt flange). Normally - the shop will do a rough cut to get both faces flat, then to a slower finish cut to get the surface finish right. You really can't cut less than about 0.003/side at a time - so if you have to take say 0.008/side off to get rid of any runout, and another 0.003/side off to get a smooth surface - you just removed 0.022 from the rotor. Taking 0.011 off a side is probably not enough to ruin the chamfer, but if a heavier cut is required, you can see why the shop would be concerned about ruining the rotor. (BTW - Each "cut" takes a few minutes, and most brake lathes are automatic, so once the cut is started the operator can walk away for a few minutes - the whole rotor cut process typically takes about 10 minutes).
So - my $0.02 - talk to the one shop that gave you a reasonable estimate and ask what the concern is about turning a drilled rotor - if the concern is eliminating the chamfer - you can choose to say - I'm fine with accepting that risk - go ahead and turn them. Take a good look at the rotor before hand, and a good look at it after the cutting, and as long as there is some chamfer left - go ahead and reuse them (the factory puts enough of a chamfer on the holes to allow for normal rotor wear - so the odds are probably in your favor.) If the shop is concerned about their equipment - there is really nothing you can do about that.. But I'd simply buy new rotors rather than paying $150 - $200. Look at either Rock Auto or one of the Chevy Dealers that sells over the internet.
I called them to find out how much it would cost to have them turned and that's what they told me. I recently had a mechanic check my brakes when I slapped on new tires and they said it was fine. So I'm sort of lost. Thanks.
I've been doing brake jobs since 1973, when I owned two service stations. I had a machine to turn rotors (and drums too, haha). Back then turning the rotors and drums was standard practice, as those parts were VERY expensive to replace. But now, it's easier (and better) to buy brand new parts. This way, with new parts, you're virtually guaranteed smooth braking for years to come.
There are numerous reasons brakes pulsate. Here's a good page that talks about 'warped' rotors: http://www.stoptech.com/technical-su...nd-other-myths
Bottom line: buy brand new and install carefully. Clean the rotors with brake cleaner before installing, and then don't get any greasy fingerprints on them. Clean the wheel hub and then use a dial caliper to check rotor runout after mounting, I like to see virtually no runout. Tighten the lug nuts to spec, in a couple of increments, using criss-cross pattern.
Smooth braking is easy to achieve, but not with resurfaced rotors. At least, that's been my experience over and over and over..........
If I have any work done by a shop I always check the torque on the lugs when I get home.
Jim
