Corsa cold air intake box
Old Jun 7, 2015 | 07:07 PM
Abel05's Avatar
Abel05
Default Corsa cold air intake box
When installing a corsa cold air intake box does it make your car sound any different? I'm new at this and I was just wondering? Thanks ! 2011 c6 base
Old Jun 8, 2015 | 02:08 PM
HK770's Avatar
HK770
Yes you can hear a big sucking sound as you open throttle. More so while still , but makes it sound more powerful. And I suppose it is making a bit more power. Like to think so with the cost of CAI .......LOL .... 11 G.S.
Old Jun 8, 2015 | 04:35 PM
Abel05's Avatar
Abel05
Thanks !!! I'm going to install mine this weekend !!!
Old Jun 9, 2015 | 08:20 AM
Tefer's Avatar
Tefer
Looks great on your car. Thinking on purchasing one for my 2013 gs, Does installation of this intake require re-tuning? and is filter oiled or dry? Thanks
Old Jun 9, 2015 | 11:24 AM
HK770's Avatar
HK770
The Corsa is pretty much straight forward and had no real directions. I'm sure no tuning is required. But I had a (Handheld tuner) on it before CAI
and made no changes.
The filter material is reddish much K&N. And K&N oil is what I put on it.
FYI = Found to place filter in place. Install CAI tight then pull filter onto CAI and tighten filter clamp.
Old Jun 9, 2015 | 02:17 PM
Cherokee Nation's Avatar
Cherokee Nation
Who makes the filter?..It looks like the filter on my K&N air charged set up.....
Old Jun 9, 2015 | 02:27 PM
HK770's Avatar
HK770
As was mentioned no real instructions, nor info on filter replacement.
I assume I will find out at the time of need.
Old Jun 9, 2015 | 03:15 PM
Tefer's Avatar
Tefer
Thanks for the info
Old Jun 9, 2015 | 08:14 PM
Cherokee Nation
I can see now that It's not a K&N...No carbon fiber on the top with...K&N on it..Very strange not to get instructions. May i ask what the cost was?
Old Jun 10, 2015 | 05:48 PM
Dano523's Avatar
Dano523
Got to ask,
How does this make the system a "Cold Air Intake" system, when it pulling the air from the same location that the stock filter was pulling air as well?
Also, the stock air filter system was already out flowing what the motor was demanding, so beside looking pretty, what is to be gained by this air filter system?
Really, looks like you dropped $600 for some carbon fiber "pretty" in the engine bay only instead.
Old Jun 11, 2015 | 12:21 AM
HK770's Avatar
HK770
Originally Posted by Dano523
Got to ask,
I suppose you might be right, if so i wasted my money. But we are all well aware of opinions.
One mans junk is anothers treasure ! Paid for mine and never stood with hand out.
Now I'll bow out : Thanks for understanding...........HK
Old Jun 11, 2015 | 07:57 AM
Tefer's Avatar
Tefer
Old Jun 11, 2015 | 07:01 PM
antny's Avatar
antny
Got to ask,
That intake looks great though. Definitely makes for good under hood eye candy.
Old Jun 12, 2015 | 11:04 AM
Cherokee Nation
C6's/LS3 from the factory are chocked out.."To Rich" so more air is needed..(Common Sense).The stock filter is trash for as air flow.
Old Jun 12, 2015 | 12:26 PM
Boomer111's Avatar
Boomer111
The Z06 427 engine uses the same LS3 filter.
The 427 has 1/2 in. wider exhaust system too.
Old Jun 13, 2015 | 03:22 PM
Abel05's Avatar
Abel05
Default Installed corsa
Installed it and now it hesitates when driving took it to the dealer everything hooked up right but MAF is getting high readings causing hesitation and backfires ? Dealer was no help!
Old Jun 13, 2015 | 05:47 PM
Abel05's Avatar
Abel05
Default Maf
Did you have any problems with your MAF after the installation??
To Corsa cold air intake box
Old Jun 13, 2015 | 06:20 PM
Tefer's Avatar
Tefer
I have not purchased / installed one yet. Still trying to decide and see if others have had any issues. Have you contacted the manufacture or place of purchase? What year is the vette you installed it on? Hope you get it resolved. I would be interested to know how it turns out so I can decide whether or not to install one on my gs.
Old Jun 13, 2015 | 06:46 PM
PDsVettes's Avatar
PDsVettes
Tefer, check out post #6 on this thread: https://www.corvetteforum.com/forums...ke-system.html. Might not be as pretty as the one above, but it does have function.
Old Jun 13, 2015 | 07:06 PM
Tefer's Avatar
Tefer
Will do, Thanks
