First time taking the vette down the track
Old Jun 8, 2015 | 07:11 PM
JHuggz's Avatar
JHuggz
Cruising
Default First time taking the vette down the track
This is my first vette and my first time taking it down the track. Also happens to be my first time racing on 4 wheels at the track.
I am fishing for some tips from the forum members here.
2010 A6 base model. (Vararam,chuck cow tune,npp) Eagle F1 runflats.
What tire pressure? (will the tpms system give me trouble if i deflate?)
Trac Cont on/off.
Paddle shift or let the tranny do the work?
Any other tips would be welcome.
I am wondering about the TC and paddle shifter because if i leave TC on i can make the pass pretty much brainless, but if i turn it off the i HAVE to use the shifters or else when i feather the throttle due to spinning the tranny will up shift to soon. (at least that has been my experience on the road so far)
Old Jun 9, 2015 | 08:36 AM
ksurfer2's Avatar
ksurfer2
Try posting this on the drag racing forum. My first time to the track was a couple months ago and I had many similar questions. The responses and help I got from that forum were VERY helpful!!!!
Old Jun 9, 2015 | 06:20 PM
tinman12's Avatar
tinman12
what i do and works well for me. air down to 22 psi, go around the water, TC off and do your burn out, back into the groove, TC on, Sport mode on, Paddle shift it down into 1st and stage, lights change and nail it down hard.
Old Jun 9, 2015 | 06:40 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Tire pressure, Automatic "D" TC off.....Let her Ripp!
Trac Cont on/off.
Chuck CoW
Old Jun 10, 2015 | 02:08 AM
HOXXOH's Avatar
HOXXOH
CoW's main market is tuning street cars to make them feel good to the driver, not for drag racing performance. Part of that tune may cause traction issues at the track, as you've already experienced some of that on the street.
I've had the exact same mods as you at one time, so I'm very familiar with what works.
Assuming the transmission tune did not change the shift points in the S mode and/or change the rev limiter, here's the procedure that will work best with your current mods.
Set tire pressure at 24-26 psi. When pulling out of the staging lane, drive around the water box. Shift to S and paddle to 1st gear. Turn TC off. Lightly left foot brake and quickly stab the throttle to break the rear wheels loose just momentarily. You only want to clean off debris from the tires, not do a burnout. Shift back into D to get out of the paddle mode and back into S mode before you pull up to the start line to stage.
I don't need to explain staging technique, but the launch is obviously different with a car. Hold the brake and bring the RPM up to the 1100-1200 range as the lights come down. Release the brake on the 3rd yellow and quickly ease the throttle open. If you have the CoW booster, this will be very difficult, since it's exactly opposite of what's needed for a good launch. (your street experience confirmed that) If you spin more than a couple car lengths, just abort the pass. The tune may grenade your engine if you attempt to recover from a bad launch.
Assuming you had a decent launch, be alert for possible traction loss on the 1-2 shift and even the 2-3 shift, due to the harshness of the tune. If the track lacks prep, as you approach the starting line, turn the TC back on.
If you master the launch, your 60' times will be about 2.0-2.1 and you can expect ET's in the low 12's. DR's will move those 60' numbers below 2.0. A dyno tune by the local shop that races their own car or does tunes for local racers can get you into the 11's without the drama.
Old Jun 10, 2015 | 09:14 AM
dennis50nj's Avatar
dennis50nj
just a heads up any tire pressure under 24lbs can cause problems
Old Jun 10, 2015 | 09:24 AM
dennis50nj's Avatar
dennis50nj
This might help with staging for the win
https://www.corvetteforum.com/forums...1&d=1433395120[/QUOTE]
Old Jun 10, 2015 | 08:12 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Thanks for the help Dennis!
Most appreciated.
Chuck CoW
Old Jun 10, 2015 | 10:12 PM
JHuggz's Avatar
JHuggz
Cruising
Just came home from the local track. Delmar De rt13 raceway.
Thanks for all the reply's
Air temps were around 90 F. track was sticky enough for me and my hard Eagle F1 run flats.
I decided on the first launch that I would rather over spin than bog or let the tranny up shift to soon. So i just turned off TC and used the paddles. I held my foot on the brake and hit the gas fast and hard but only about 1/2 down (made sure i spun a little and didn't bog but also didn't let the rpms go over 3k) then slowly pushed it all the way to the floor, and press the up shift paddle as soon as the tack read 6k so it had time to shift before red line.
The results........................... 1.9 sixty foot, 12.1 et, 118mph!!!
was so happy i did the exact same thing the second time and got the EXACT same times.
Special Thanks to Chuck Cow for the killer tune. I cant believe i went 12.1s with a base A6 on Eagle F1 run flats, and only a vararam and Chuck Cow tune in 90 heat!
(and yes i have it on video, but it's on my wifes galaxy note edge, and i'm not sure how to upload, but i will give it a try soon)
skip to 1:20 for staging
second run
Old Jun 10, 2015 | 11:04 PM
dennis50nj's Avatar
dennis50nj
second run
Great job good time and your wife was very happy that means you will be going fasterI think you would have made 11s if you left it in sport mode
Old Jun 11, 2015 | 03:23 AM
HOXXOH's Avatar
HOXXOH
second run
Glad to see you got good times first time out. Most people take more seat time to get to that point. Those times were nearly identical to mine first time out with the Vararam, local dyno tune, and OEM RF's. 1.903 60', 12.144 ET, 119.16 MPH, so you're right on target.
If you can feed in the throttle a bit smoother to be on the ragged edge of spinning up to WOT and you'll squeeze into the 11's.
Old Jun 17, 2015 | 01:49 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Awesome!
second run
Awesome! A few tweaks and you'll go even faster!
Glad you like my stuff!
Thank you.
Chuck CoW
To First time taking the vette down the track
