DTC Messages and Engine light on
- Maximum speed 158 MPH
- Service Active Handling System
- Service Ride Control
- Service Traction System
Also as I slowed down the automatic transmission seemed to down shift to second gear and stay in second. If I restart the car the engine light stays on, but the DTC messages and second gear issue takes a little while to pop up. If I disconnect the battery and reconnect, the engine light goes off, but after a while it all happens again. It got better over a month or so of driving, but when I washed it, the problem came back with a vengeance.
I pulled the error codes and found P0575, P0700, U0073, U0140
Good luck.
Check the ground at the left side of the block just fwd of the engine mount. That is the ground for the EBCM.
Also check all the connectors and wiring leads for the Selective ride.
If the problem got worse after washing , leads me to believe you're getting water intrusion into a harness or component
I am sorry it is taking so long to reply that my problem is resolved. Replaced the F55 Select Ride Control Shock Module and the problems are gone. I was very lucky to do business with a shop that felt strongly the module was at fault, but couldn't guarantee a new $600+ F55 module was going to fix it. The shop let me pick up a F55 module used from EBAY with a two week return policy just in case it wasn't an F55 issues.
Thanks for everyone's suggestions
