cooling fan motor died :(
Old Jun 14, 2015 | 09:12 AM
ZHZ-416ci's Avatar
ZHZ-416ci
Default cooling fan motor died :(
Hi All, now I'm facing a problem with engine cooling fan and after checking the fan motor should be replaced, I tried to find a part number or oem replacement motor but I couldn't find any all what I got is a full assembly cooling fan OEM,TYC,Depo...etc
I can't go for performance upgrade fan cause it's very expensive to me
So any suggestions?
[/URL]
Old Jun 14, 2015 | 09:33 AM
4SUMERZ's Avatar
4SUMERZ
So any suggestions?
[/URL]
Unfortunately, GM does not sell only the motor, but the fan assembly including the plastic grill Part # 15819952 for the whole assembly
$260.00 or so at forum vendors (GM partsdirect or at CultragPerformance)
Try to find an electrical supplier in your area that has replacement motors.
I found one in my small city, so I'm sure you have one in your area. They can match any motor from any application. You just need the info stamped on the side of that motor that's bad.
Good Luck
Old Jun 14, 2015 | 09:41 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
I've got one. I'll get some pictures today. Not sure of your location, but it looks like you're overseas. Would like to get $60 plus shipping. PM me if your interested.
Old Jun 14, 2015 | 09:44 AM
4SUMERZ's Avatar
4SUMERZ
^ Problem solved.... Another forum member to the rescue
Old Jun 14, 2015 | 11:44 AM
ZHZ-416ci's Avatar
ZHZ-416ci
PM sent
Old Jun 14, 2015 | 11:52 AM
ZHZ-416ci's Avatar
ZHZ-416ci
Good Luck
Thanks for all these info, is it hard to release the old motor?
Old Jun 14, 2015 | 05:46 PM
erick_e's Avatar
erick_e
It's not too hard at all. Just a few bolts holding the motor to the shroud. The hardest part is getting the shroud out.
Old Jun 17, 2015 | 07:17 PM
ZHZ-416ci's Avatar
ZHZ-416ci
Ok can you tell me what size of socket I to use for this bolt?
To get it out?!
Old Jun 17, 2015 | 08:30 PM
HOXXOH's Avatar
HOXXOH
I've never heard of the motor dying, but there have been many reports, including mine twice, where the connector shown in erick_e's 3rd photo has severely burned contacts. If the contacts burn out, the fan quits. I hope you checked this first. I did a hardwire bypass after the second one burned up.
Old Jun 17, 2015 | 08:57 PM
ZHZ-416ci's Avatar
ZHZ-416ci
I tested the motor, the fan not going for the fastest speed + the fan blades were very heavy and hard to move. So the problem is from the motor, evry thing else work great!
Old Jun 18, 2015 | 09:12 PM
erick_e's Avatar
erick_e
To get it out?!
Once you get the shroud assembly off, hold the fan blade still and rotate the 15mm nut/shaft counterclockwise to unlock the three locking tabs and the fan blade will come off. Then you can remove the bolts holding the motor to the shroud to remove it.
Old Jun 19, 2015 | 10:42 AM
Dano523's Avatar
Dano523
Once you have the motor in hand, see if you can spin it or not by hand.
Have not pulled a vet fan motor down to service it, but even sealed motors with bent over tabs can be pulled apart to either clean the Bronze bushing,/clean and re-grease or replace the bearings.
Worst case, you pick up erick_e for around $100 with shipping, and Bob's your uncle.
To cooling fan motor died :(
