Ok pulled motor out couple months ago to fix. Never unhooked anything from master cylinder or slave cylinder.
Got everything back in car and running great, but the clutch won't disengage. I tried to bleed the clutch couple times and seem to not have any air.
No leaks from slave cylinder, and mast seems to build pressure up as fluid shoots out when opening my speed bleeder.
Any input would be great, or maybe I'm not bleeding it right idk.
Brand and friction material type.
The reason i am asking is, on occasion over the years I have seen under certain conditions the clutch disk sticking to the flywheel.
Thanks in advance for any help.
Give us a call and we will go over details about your setup, and help you trouble shoot the issue. (817 750-2000)
