***RSD All Aluminum Radiators***
Old Jun 18, 2015 | 04:33 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
Default ***RSD All Aluminum Radiators***
Anyone who wants their LS engine to run cooler should put one of these in their car and replace the thermostat reprogram the fans to reep the benefits of a cooler engine. Our Radiators are Dual Core 1 1/4" core, Total thickness 2 1/2". That is 2.5 times thicker than the stock radiators! In Most cases it is a direct replacement in your car. (The Cutdown radiators require a bit of fan shroud work.)
We also build a 3" cut down radiator for the Vortech and Procharger supercharger guys. With the 3" cut down unit you can use a 4" air filter pipe to increase boost in your supercharger instead of the restrictive plastice dongle.
All of our radiators are available with either oil coolers or Transmission coolers.
Buy them here:
RaceSpecialtyDesigns.com
Steve
Steve@RaceSpecialtyDesigns.com
Old Nov 9, 2015 | 10:05 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
Anyone who wants their LS engine to run cooler should put one of these in their car and replace the thermostat reprogram the fans to reep the benefits of a cooler engine. Here is a comparison of the Stock Radiator to ours. More than double the thickness and capacity!
Buy them here;
http://www.racespecialtydesigns.com/home.php
Steve
Old Feb 29, 2016 | 11:34 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
Buy them here;
Steve
Old Mar 6, 2016 | 07:54 PM
Steve@RSD's Avatar
Steve@RSD
St. Jude Donor '13
Buy them here:
Steve
To ***RSD All Aluminum Radiators***
