Issue with front lowering bolts
Old Jun 20, 2015 | 05:29 PM
Denis_C6-Z's Avatar
Denis_C6-Z
Default Issue with front lowering bolts
I'm having an issue with the front bolts, I can not break them loose no matter what I try. Is there a certain way to this? Ive supported the car, the spring, the spindle, still cant get it loose. Any ideas or help would be appreciated.
Old Jun 20, 2015 | 06:14 PM
timd38's Avatar
timd38
BP Blaster?
Old Jun 20, 2015 | 07:11 PM
Denis_C6-Z's Avatar
Denis_C6-Z
Originally Posted by timd38
BP Blaster?
Tried it. Let it soak for half an hour. No luck, didn't want to break the bolt.
Old Jun 20, 2015 | 07:16 PM
RicK T's Avatar
RicK T
Haven't dealt with it personally but most people used to recommend letting it soak for 24-48 hours. I haven't seen a discussion in a long time so I don't know if that's still true. May be worth a try since you're having trouble though.
Old Jun 20, 2015 | 07:41 PM
Cor430vette's Avatar
Cor430vette
THis...better than PB blaster give it a try, worked for me
Old Jun 20, 2015 | 11:27 PM
Kent1999's Avatar
Kent1999
Are you *sure* you're lifting JUST the spring end and not putting upward pressure on the a-arm too?
You HAVE to get the spring end to lift off the a-arm before the bolt will move, as upward pressure of the a-arm is what keeps the bolt from turning under normal driving conditions.
https://www.corvetteforum.com/forums...post1589671379
Old Jun 20, 2015 | 11:33 PM
Cor430vette
Yep that would definitely cause it to not move! ...in case OP you never saw this video:
To Issue with front lowering bolts
