Brakes Suggestions?
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Tx
If you do track days and really pound the brakes - then a aftermarket brake pad that is designed to live under that kind of use is a far better choice.
The engineers that develop brake pads have to trade off a lot of different (and sometimes competing) concerns. There are probably more compromises made in brake pad formulation than in tire design. Things like brake noise, low temp performance and dusting are utterly unimportant to the people who race, whereas things like very high temp performance the initial "bite" characteristics and keeping a linear coefficient of friction across a wide temp range are not important for "daily driver" applications.
You say you have a GS - the OEM brakes the car comes with are truly amazing - there is very very little out there on the street that can out stop a Z06 C6. I've felt what a bone stock Z06 Brake system can do at the track - and unless you are a pretty accomplished driver - I don't think you're going to fade that system very easily. So - Did the old brake pads perform acceptably as far as you were concerned ??? If so - you probably have your answer...
If you want something a bit more aggressive - there are lots and lots of choices out there - Carbo-Tech, EBC, Hawk, Performance Friction and many many others, all make pads with that will deal with hard use better than the OEM formulation will, albeit with some compromises in other areas.
If the rotors are in good shape - meaning not worn and no problems with run-out (read that a pedal pulsation), AND if you're not changing the brake pad compound - there is no NEED to turn the rotors. If you are changing pad compound - then a light sanding and a fair amount of brake clean is probably enough to allow the new pads to bed in properly. If you have pedal pulsation - you can try turning the rotors - but the odds are the problem will return - new rotors are the normal "solution" to pedal pulsation problems. Significant wear on the rotors or cracking means you get to buy new rotors !!!
One last word of advice - if you think you can re-use the old rotors - make sure to get the pads changed before they wear out completely, and you get to metal on metal - if that happens then you definitely need to get new rotors, and while the rotors themselves aren't that brutally expensive, it does take about twice as long to do brake pads and rotors as it does to change brake pads alone......
