steering wheel
Old Jun 24, 2015 | 12:28 AM
73ls1's Avatar
73ls1
Default steering wheel
The steering wheel on my 06 is sticky and I want to change it. Bought a steering wheel from a member that is a non paddle shift. Can I use it in my 06 with paddle shift? Did they have 2 different wheels?Thanks Charlie
Old Jun 24, 2015 | 04:17 PM
Kent1999's Avatar
Kent1999
I believe you can transfer the paddles from your old wheel to the new. You'll probably have to transfer the wheels internal wiring harness from the old wheel too.
Old Jun 24, 2015 | 06:48 PM
Dano523's Avatar
Dano523
Here you go,
So pull your old and new steering wheel down to the base wheel, and then build the new wheel back up with your old parts.
And the next time you need to replace the leather on the wheel, check with some locally car upholstery shops, since chances are they can re-lace the wheel with new leather/color of your choice (and even stitching color) for less that the cost of a new wheel.
Better yet, take the wheel with you on your next trip to Mexico, and you can get it redone for dirt cheap instead (might have a problem getting it back through customs if you have an exotic leather used instead). Hell do it right and you should be able to get machining set of boots/loafers as well.
To steering wheel
